Thread: Vacation success!
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    Vacation success!
    This is my first year attempting BBB. I went through a whole ordeal with shocking and balancing after opening (this site is godsend!) but had finally almost cleared everything (still working on high TA) up about three days before we were supposed to leave for vacation. The morning we left, I raised the FC to shock level, threw a zpack of pucks in the chlorinator, double checked our pump timer settings, and got in the car - fingers crossed.
    For 10 days, I had horrifying self-imposed visions of a nasty mess when we came home. Even though I knew I'd done everything right and to the best of my ability, I was terrified of finding a green swamp.
    The first thing I did when we arrived home was run out back to check the pool - never mind the now beyond dead grass that used to be our lawn (yay for an early hot summer!). I found it rainbow sparkly clear - albeit it had quite a bit of sawdust at the bottom (the deck is under construction still). I ran all the tests - everything (except that stinkin' TA still) came back within acceptable range.
    Yay!
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    22,551
    Re: Vacation success!
    Whoohoo!
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    May 2012
    Minooka, IL
    93
    Well, I think I discovered the source of my TA problem... LOL. For giggles, I tested the water coming out of the hose. TA was 290. So, I guess every time I top off the pool after massive kid splashing, I'm setting myself back on the TA. Oh well, forwarned and all that...
    22,551
    Do you have a water softener? If so you could top the pool off from that.
    Jun 2008
    Marana, AZ
    347
    Yay!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
