Thread: Rewiring Intex salt water chlorine system bypassing pump
    I need a wirng diagram/schematic to rewire my intex salt water generating system bypassing the pump. The pump went bad on my intex system and I have a sand filter pump that I want to use but I only want to wire up the generating system so I can run it with the sand filter.
    Jul 2007
    Hillsborough, NC
    525
    Re: Rewiring Intex salt water chlorine system bypassing pump
    You probably aren't going to find one. Can you plug it in and just use the SWG, or will it not come on unless the pump is running? You may have to crack the cover and do some exploring.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Welcome to TFP!
    Some people simply cut off the wire running from the control unit to the pump motor (wrap the cut ends with electrical tape).
