Thread: Liner /refill
    Liner /refill
    I drained my above ground pool it has a beaded liner and I know that when you fill a pool you use a vacuum to get the air between the wall & liner out what do you do if the return and skimmer are already cut out and you need to get the air out do you lift the bead off the wallany suggestions would help
    22,548
    Re: Liner /refill
    Welcome to TFP.
    Yes, just pull a small section of the bead out and let the air out.
