Thread: filter run time
    filter run time
    I have an Intex 16 x 48 AG pool. I have very cloudy water (I can see down to the 2nd ladder rung, then extremely cloudy. I have taken samples to the "pool" store and now have my PH & chlorine levels where they should be. My pump is the one that came with the pool. My question is how long should I be running my pump in order to clear up the water. It is on a timer and I have it cycled every 4 hrs....
    Also, I am wondering if it would help to detach the skimmer basket & push it closer to the bottom of the pool in the hope that it would better filter the lower portion of the pool?
    16 x 48 Intex Ultra; Intex 1600 sand filter/pump;
    TF50 test kit
    Crosby, Tx
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: filter run time
    24 hours a day except when there are swimmers in the pool. They are generally undersized and can barely keep up when running all the time.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: filter run time
    2 parts to the solution:
    - adequate pump/filter time
    - proper testing
    So, up your pump time and buy a good test kit. Testing every evening is very normal and doesn't take that much time, it will also empower you with the knowledge of what/why is happening with your water and not leaving it up to someone that may/may not know what they are talking about.
    Re: filter run time
    Are the pump/filters that come with the Intex 16 x 48 pools efficient enough to clear up the water?
    TF50 test kit
    Crosby, Tx
    SW Indiana
    9,199
    Re: filter run time
    Quote Originally Posted by rickyjanet
    Barely in most cases. That's why they need to run so much.
    Mar 2012
    NC
    138
    Re: filter run time
    Quote Originally Posted by JohnT
    So does that mean you should not run the pump when people are swimming? I always thought it was the other way around. Hopefully I dont sound like a asking that question
    33' Seaspray Aegean II - 6' Deep End
    28K Gallons
    2" Hard Pipe Plumbing
    Hayward S244T 300 lb. Sand Filter
    1 HP - 2 speed - Powerflo Matrix Pump
