Thread: Daily Chemicals
    Jun 2012
    Howard City, MI
    54
    Daily Chemicals
    Is it normal to need to add chlorine and stabilizer every day? The amounts I need to add have gotten smaller, but I still am adding every day. Just want to make sure this is a normal routine or if I am doing something wrong.
    Above-Ground Pro Series 18'x48" Metal Frame - Approx 6,450 gallons
    Skimmer Filter System (cartridge): SFS1000 w/ F1500C Pump: 120watts/2.0amps/1500g.p.h
    Purchased & Installed: 6/7/12 (week of)
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Daily Chemicals
    Quote Originally Posted by Terrjam
    Adding chlorine daily is normal, but adding stabilizer daily is not normal.
    What are you adding - exactly?
    Can you post current water test results?
    You're done SLAMing when:
    Re: Daily Chemicals
    Stabilizer which establishes your CYA level, is never added every day as part of the BBB method. Adding too much will make your CYA level too high and caring for your pool very difficult.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Jun 2012
    Howard City, MI
    54
    Re: Daily Chemicals
    My levels are:
    fc 3
    pH 7.5
    cya 30-50
    I have the liquid drops test kit which only has enough to test cya about 2 times. where do i get more stuff to test cya without buying the entire kit? or is it not necessary to test cya as long as my ph and chlorine are good?
    I have been using the hth Stabilizer and Conditioner powder which contains cyanuric acid.
    Re: Daily Chemicals
    My levels are:
    fc 3
    pH 7.5
    cya 30-50
    What test kit are you using? What are your CH, TA and CC levels? CYA levels do not need to be monitored too frequently unless you are using stabilized chlorine. Using the BBB method, you can sort of "set it and forget it."
    10,000 gallon
    NC KANSAS44
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Daily Chemicals
    CYA should be added very carefully, with a specific target in mind. You can only reduce CYA by replacing water, or performing RO on your water. Assuming you are not adding CYA as part of chlorination, in addition to the conditioner you have been using, it would be best to use the Pool Calculator with a full set of test numbers to make any further decisions about adding things to your pool. Also, CYA can take several days to show up in test results. A rule of thumb is to add 1/2 to 2/3 of the Pool Calculator recommendation, and wait seven days to test and add the rest if needed.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
