Results 1 to 9 of 9
Thread: Haward plastic drain. Is the cap on it removable?
    May 2012
    Allentown, PA
    219
    I have algae under the drain cap and want to remove it because I cannot get it with the brush or even a paintbrush. Can I remove the cap with out effecting the vinyl liner seal? The cap looks separate from where the drain seals to the liner. Obviously I would turn off the pump before trying to clean it. Or any other suggestions. I have the pool well above shock level and it is not eating away the green algae. Thanks
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    22,553
    Re: Haward plastic drain. Is the cap on it removable?
    If you're talking about the drain cover/grate, it's separate from the actual drain fitting and can safely be removed. There should be a couple of screws holding it in place.
    May 2012
    Allentown, PA
    219
    Is there a better way to kill the algae, then removing the cover underwater upsidedown? CYA is 30 what target level should take care of it? Thanks
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Quote Originally Posted by doublewide6
    Maybe your valves are set in such a way that no water is being drawn through that drain?
    Dan
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    May 2012
    Allentown, PA
    219
    I double checked and the valves are open going to the main drains.
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Going through the shock process should take care of it. See Bama's signature (above) for the pool school link.
    Dan
    May 2012
    Allentown, PA
    219
    Thanks for the suggestions. I shocked and it did not clear up, so I went down swimming with my screwdriver and brushed under the cap.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    When you say "shocked" the pool. Did you use a bag of shock or did you do the shock process and pass your OCLT test. If you don't know what I mean, read the pool school. There is a link in the upper right corner of this page... here's another LINK
    -- Guy --
    May 2012
    Allentown, PA
    219
    I used bleach to shock to a target of 20 and Passed the OCLT last night. I don't know why I got algae I have been keeping my FC high 5-7 range until I get my CYA above 30. I had a few spots where I saw algae developing, so I decided that had to meet the 3 requirements of shocking to move past the algae stage. Everything looks great I just hope it holds up. Thanks
