Thread: Discoloration on pool floor
    Mar 2012
    Kansas City, MO
    59
    Pool is getting better/clearer. There is some discoloration in the deep end (left side of pic, the white circle is the drain) that won't come off with a brush. I don't know if it's paint peeling or some sort of stain? Sorry, but this is the best picture I have at the moment.
    Uploaded with ImageShack.us
    Any ideas?
    15k gallon IG kidney pool with attached spa
    plaster
    sand filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Discoloration on pool floor
    Try holding a trichlor puck on the stain for a couple mins to see if it lightens.
    If no results from the puck, try crushing some cheap vitamin C tablets in a sock and hold the sock on the stain for a couple minutes.
    You're done SLAMing when:
