Thread: Is it ok to have low TA?
    N.E. South Carolina
    Now that we are kicking back into high gear with the pool, I'm testing and see that my TA is 40. I remember last year I had to add stuff a few times because my TA drifts down. Is there a reason (other than to try to stabilize PH) that low TA is bad? I have a vinyl pool, with a heater that we rarely use.
    Also, someone remind me which raises PH and which raises TA (borax or baking soda). I seem to have forgotten everything over the winter!
    Designated "pool girl" for 18' x 40' in-ground vinyl pool built in 2006
    Butterfly's Avatar
    South Carolina
    You can go to the Stickies (link in my sig) and read: "BBB or What are all these pool chemicals?".
    I had to re-read them, too
    You're done SLAMing when:
    40 is quite low. I would raise it to at least 50, preferably 60.
    You raise TA with baking soda, which will raise PH just a little.
