Results 1 to 7 of 7
Thread: Cutting a liner for new intake and return. With pics.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    I have a new Summer Escapes pool (see sig). If any of you have a pool like mine you will know that the included pump and filter system is very inadequate. I already had an intex sand filter, so I cut new intake and return holes for the sand filter, leaving the included pump set up as intended. This is the first time this pool was set up, so it was only about 1/4 full when I did this, making the job much easier. However, it can be done when the pool is full also. I've done that before as well with no problems. Not sure if I will get the pictures in correctly, but I'll give it a shot. Anyhow, here is what I did:
    1. I first reinforced the area to be cut with a piece of vinyl patch material. This is NOT a necessary step, but my neighbor had a vinyl repair kit (he works in the upholstery repair industry so I figured I may as well use it).
    2. I then used the rubber gasket for the Intex intake/return as a template to draw a circle on the reinforcement. (Use the inside circle of the gasket not the outside!!)
    3. I then VERY CAREFULLY cut along the outside of the circle using a utility knife with a fresh, sharp blade.
    4. Then I installed the new intake/return nozzle.
    https://picasaweb.google.com/gpomroy...eat=directlink
    The pool is filled, and all things working fine.
    IMPORTANT!! When cutting the hole, do not try for a snug fit. Slightly too big is good. If it's a snug fit, you will more than likely have leakage. I (as well as others on this forum) have experienced this.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Apr 2012
    Louisiana
    13
    Re: Cutting an Intex-type liner for new intake and return. W
    You could have also cut the circle out on the vinyl patch before gluing it onto the pool liner. I find it makes and easier and safer cut to the liner as the knife is guided along the added patch. Just saying.
    Jul 2011
    844
    Yep. Could have done it that way. But for me I would just as soon make 1 cut instead of 2. Also, if you're not adding reinforcement, you can't do that. If you're careful and your knife is good and sharp, you won't have a problem. That being said, your idea is probably a great way to go for someone who may be a bit intimidated - or first timers!!
    Bestway SWG
    Apr 2012
    Louisiana
    13
    Oh yeah. Slip of the blade can be a costly mistake. I know cutting my $1k pool was a little intimidating. But I manned up! Did it at night.... In the dark..... LOL which I definitely don't recommend.
    Jul 2011
    844
    LOL. You are a brave soul!!
    Bestway SWG
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Cutting a liner for new intake and return. With pics.
    Thank you for this... I am planning to do this for a dedicated feed to my solar heaters...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Orlando, FL
    690
    Is the things that looks like a fan your solar heater? What brand?
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
