Results 1 to 11 of 11
Thread: Losing Chlorine Too Rapidly
    Aug 2009
    Bloomington, IL
    11
    Im near my wits end.
    Ive been using the BBB method for 5 years and it has been very successful. However, Im having a problem this year holding chlorine.
    This is the 3rd time in a row this situation has happened this season. Heres the info for the latest occurrence:
    Readings as of 7 AM this morning, June 25th
    FC = 9.5
    pH = 7.6
    TA = 140
    CA = 300
    CYA = 40
    Ammonia = 0.0
    Phosphates approx. 200 pbb
    6/23 3:00 PM Brought the pool up to shock level (16 ppm)
    7:30 PM FC = 16.0
    Ran the pump all night.
    6/24 6:45 AM FC = 16.0 (OFCT seemed to be successful.)
    1:45 PM FC = 15.0 (Opaque covered had been closed until 1:45 PM)
    5:30 PM FC = 13.0 (Pool had been exposed to sunlight and 4 teenagers for 3 hrs and 45 min.)
    7:00 PM FC -= 12.5
    Pumped turned off at 7:45 PM
    6/25 6:00 AM Pump turned back on.
    7:00 AM FC 9.5 (Lost 3 ppm in 12 hrs while the cover was closed and the pump was off)
    This is the 3rd time in a row that this has happened. Overnight Free Chlorine Test indicates there are no algae in the water. Then over the next day or two the chlorine level drops significantly indicating there is something consuming the chlorine.
    Ive pulled the light and cleaned behind it. Ive brushed the entire pool. Ive swam using a mask looking for any discoloration on the liner and found none.
    Any suggestions?
    Thank you.
    IG
    27,000 gallons
    DE filter
    BBB Method
    Taylor K-2006C Test Kit
    Opaque automatic cover.
    Pool usually covered unless there are swimmers.
    steinholder's Avatar
    Mar 2012
    Wichita, KS
    81
    Re: Losing Chlorine Too Rapidly
    Combined Chlorine is a very important test result, that is what tells you if you have something consuming your chlorine.
    22'x52" AG Ultra Frame Intex - 12,500 gal (47K liter)
    Manual Liquid Chlorine - 1HP 100# Hayward sand filter
    Lots of sun, trees, pollen & wind - 50ppm Borates
    4nd season grateful TFP fan
    22,548
    Exactly how much FC are you losing per day in ppm?
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Aug 2009
    Bloomington, IL
    11
    Bama Rambler - From 7:00 AM Sunday to 7:00 AM today (Monday) I lost 6.5 ppm. The pool was open to sunlight about 4 hours of that time and the pump ran about 9 hours. On the other two occasions like this, the water eventually turned cloudy.
    IG
    27,000 gallons
    DE filter
    BBB Method
    22,548
    That's a lot and with it being closed it surely seems like something is going on but I don't know what. Have you brought it to shock level?
    Quote Originally Posted by steinholder
    +1
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Aug 2009
    Bloomington, IL
    11
    Bama Rambler - Yes, I have brought it to shock level. I did the shock method as outlined in the Pool School. I didn't quit bringing it to shock level until the Overnight Free Chlorine Test showed no loss and the water looked clear. I never have much CC chlorine. It is always 0.5 for less. I've been using this method for 5 years and I've never experienced a problem like this. I've considered bringing the shock level to the mustard algae level. Do you think that would be a logical next step?
    One other thing, when I look in the skimmer there is a film floating on the water with a few big bubbles in it. This covers maybe 1/3 of the water surface in the skimmer hole. Does that indicate a problem? I don't think it is sunscreen residue.
    IG
    27,000 gallons
    DE filter
    BBB Method
    22,548
    MAybe it's time to clean behind the light and everywhere else something could be hiding.
    Aug 2009
    Bloomington, IL
    11
    Yes, I've done all of that - cleaned behind the light, brushed everywhere, even put all the "toys" in the shocked pool. Do you thinking bringing the pool to mustard algae shock level would be warranted?
    IG
    27,000 gallons
    DE filter
    BBB Method
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    What about the waterside of your auto cover?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Aug 2009
    Bloomington, IL
    11
    Harleysilo - Actually, I've wondered about the waterside of the auto cover. When I shock the pool, the cover floats on the shocked pool. Shouldn't that deal with any algae on the cover? How would I clean the cover?
    IG
    27,000 gallons
    DE filter
    BBB Method
