Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: My Baqua to Chlorine Conversion Adventure...
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    After lurking on the "Baqua - Use and Conversion" bbs for about a week, and after seeing all the support that the admin and other users give through this process, I began my own conversion to chlorine today! I'm going to post my experience in the hopes that others can learn from my mistakes (that are bound to happen!) and makes the process easier for them.
    So far today: I started with a very low Baqua level (never added any since uncovering the pool and getting the sand filter running about a week ago). I started with fresh sand in the filter (D'oh! I realized only after looking into the conversion that I will have to change out the sand after...). I used the Pool Calculator to tell me how much bleach to add.
    At 3pm, I added 824 oz of 6% bleach - the water went from pretty clear to cloudy, but still mostly blue.
    At 4:30p, my hth 6-way strips from Wally World told me:
    FC - 0
    ph - 7.2
    TA - 80
    TH - 200
    CA - 0 (maybe 30? The color is not much different for 0 and 30...)
    At this point, I added 824 more oz of the bleach. The water turned a murky grey-green with some brown swirls...scary and swamp-looking!
    At 6:30p, the tests said the FC was at zero again, and everything else was the same. The water looked less grey-green, but still cloudy blue-green. I added 824 more oz of bleach.
    At 8:15p, I tested again and the FC was at about 5, the other levels were the same, and my wife described the water as "milky sea-foam green" (Beautiful description...I love this woman...) I used the Pool Calculator again, and added 550 oz of bleach. I'll check again first thing in the morning before going to work, and add bleach accordingly. So far, so good - I guess?? : )
    21,200 gallon, 30' round above ground, 48" actual water depth, installed August 2010. Hayward E200 sand filter, Hayward pump, vinyl liner. Converted from baqua to BBB July 2012!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    6,764
    Re: My Baqua to Chlorine Conversion Adventure...
    For now the strips will lead you somewhat, but your progress will be slowed greatly using them
    I highly suggest a good test kit as in the long run it will save time and cash.
    Good luck....we're here for any questions!
    Apr 2012
    Bonner Springs, Kansas
    109
    Sounds like you're on your way! As Leebo noted, a good test kit is definitely an investment in your long term success! I Highly recommend the TF100 - with the speedstir and XL option - for the testing you will need to do during the conversion - it's well worth every penny.
    Keep the same schedule for adding chlorine. Test, add, wait - if possible every hour or so.
    One last thing. Brush to ensure you're getting everything out and into the nice chlorine bath. If you've been reading the forum, you've probably read NikiBelle's posts - but here is the revelation post - help-i-m-in-a-complete-mess-and-don-t-know-which-way-to-turn-t44455-260.html#p388976 Brushing is critical to the process!
    Good Luck!
    16'x32' -> 3' shallow, 8' deep ~22,000 gallon igp - Vinyl Liner.
    Sand Filter: Jacuzzi 225l-7 Sand Filter - 250lbs
    Pump: Hayward Max-Flo XL 1hp
    SWG: CircuPool RJ+ 60
    Water Source: Home Tap water (TA:230, CH:220)
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    THANKS!! I really appreciate the support and guidance - I'm ordering the TF100 kit tonight. I do have a question - since the starting baqua level in the pool was low, will the conversion be faster?
    Yes, faster, but not a huge difference. The main thing controlling how long the process takes is how frequently you add chlorine during the first few days.
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    OK THANKS!
    This morning:
    FC 3
    Adding 659 oz of bleach
    NikiBelle's Avatar
    May 2012
    Knoxville, TN
    450
    Just wanted to send you some "adda way to go" strength. Your pool was clear at first, mine wasn't. I'll bet yours will go faster. That TF 100 kit has been my life preserver. Well that, and the peeps here.
    Don't forget to brush!!!! Way more than you even think is needed....
    Hang in there and you'll do awesome!!!!!
    10,700 gal Round; Vinyl liner,
    New Hayward pump ProFlo 1.5....150 lb. sand filter.
    Baqua to BBB.....BBB is the only way to go!!!!
    A Cinderella story with a "happy ever after" ending.
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    Thanks! Having read through your experience, I know you've been through it all! The TF kit is on its way; til then I'm using the cheap test strips to measure FC. I'll spend the evening brushing and brushing... : )
    Jul 2011
    Chambana, Illinois
    40
    Congratulations on your decision to convert! You will not regret it.
    Test strips are usually not accurate at higher chlorine levels.
    You could dilute your pool water 2:1 or 3:1 with distilled water to get a more accurate FC reading until your test kit arrives. Don't use tap water to dilute, it has chlorine in it!
    Good luck!
    12,000 gallon IG vinyl pool, 1 HP pump, sand filter, TF-100 test kit, Raypak heater. Converted from Bacqa June 2011. Trouble Free ever since.
    NikiBelle's Avatar
    May 2012
    Knoxville, TN
    450
    Quote Originally Posted by buglogger
    Good for you!!!! You make me proud!!!!
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    This evening's progress:
    At 5:30p, the FC was 0, and ph has dropped to 6.8. I added 824 oz. bleach, then brushed and vacuumed as much as I could (my vacuum works poorly). The water is transparent, with a greenish hue. It's lost the cloudiness, and I could see the sediment on the bottom of the pool. As I brushed, I could begin to see little bits of stringy white goop floating throughout the water - the baqua goo I assume? Checked FC again at 8:15p after brushing all that time, and it was at 2, so I added 714 oz. bleach, then went to Wally World to get more. Now, this is no joke - I've seemingly single-handedly cleaned out the Walmart's bleach section. I bought 11 jugs Saturday, 16 on Sunday, and tonight I bought the remaining 5 jugs! That will only be enough to get me through the morning's dose - hope they have more by tomorrow afternoon! : )
    Jul 2011
    Eastern Ohio
    6,764
    We filled ours with water and used them to hold down the winter cover last year. Now that I think of it....wonder what we'll use this year?
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    HA! I love it! That's what my garage looks like now! But the results are showing - this morning the FC was 3, so I added more bleach, and the water is getting very clear. The pool is looking inviting! The ph is at 6.8 - should I start to address that now?
    Jul 2011
    Eastern Ohio
    6,764
    When did you test the ph level.....before or after you shocked the water?
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    I've been testing the water each time before I add the bleach.
    Jul 2011
    Eastern Ohio
    6,764
    If your PH was below 7 before you shocked I would bump it up to 7.2 after that ignore the other tests besides FC and CC
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    OK thanks Leebo - when I started the process, it was at 7.2. and it's now gone down to 6.8. I'm only using hth test strips until the TF100 kit arrives, which test for FC, ph, TH, TA, etc. If I'm hearing you right, I should go ahead and work on bumping up the ph?
    Jul 2011
    Eastern Ohio
    6,764
    I would as I never wana see a ph below 7, but using strips I wouldn't worry about it much. If you don't feel 100% positive with your results on PH then just wait.
    At this point the FC level is still your biggest worry.
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    8pm FC was 0 as expected, so added bleach accordingly - water is clear and inviting! Can't wait for the next step now.
  20. Back To Top    #20
    buglogger's Avatar
    Jun 2012
    Marydel, DE
    30
    Well, the water is still nice and sparkling clear! The FC this morning was about 3-5 (the strips are really hard to read), so I split the difference and added the appropriate amount of bleach for 4 FC.
    Am I ready now to begin the next steps? The wife and kids are looking at the pool and seeing how clear it is, and they are ready to swim! I get looks of confusion and disappointment when I tell them "not yet". Where do I go from here? The TF100 can't get here fast enough!! : )
