Results 1 to 7 of 7
Thread: Suitability of pool water for personal ingestion
    Oct 2010
    Mesa, AZ
    63
    BORAX: This looks like an excellent way to raise PH.
    WallyMart, Costco and Target had none. I finally found it at Ralph's and Stater Brothers for about $4 for a 76 oz box here in the People's Socialist Republik of Southern Kalifornia [henceforth: PSRSK.] This is still waaaaay cheaper than the ~40# (??) bucket of soda ash I paid about $80 for at Leslie's five or so years back; waaay too many pounds, waaay too $$, and waaay too nasty on the TA levels.
    Thus, a few questions, _'sil vous plait_ :
    I look at my 16K gallon pool as a source of drinking water should the grid, northern or Colorado River aqueducts, or WTW-evah ever go down here in the PSRSK, depriving us of water in this area that is a total desert by nature.
    As is, after a complete analysis, I expect I could drink / cook / etc. with my pool water for a very long time, as long as I added a modest amount of chlorine to anything that was not boiled first [mebe I should get the CYA down below 100 ppm...]
    Here are the QUESTIONs:
    What effects do
    ---borax
    ---CYA
    have on the suitability of pool water for personal ingestion over a period of perhaps a year?
    Methinks the rest of the factors outside of FC do no matter(?)
    tanks
    pc
    RECENT ANALYSIS STATS:
    FC: 16 (let's not overdo it next time, just got the T-100 kit!)
    PH: 7.3 to 7.5
    TA: ~130 on average (tap water is 120 to 190 on any particular day)
    CH: 300 to 400
    CYA: 100
    "Nice weather here, but the lack of _even basic_ intelligence in Sacramental is disturbing."
    IGP California Pools | Gunnite-Pebble Finish | ~2 yr. old ~12.5K gallons salt water| Triton 400 | T15 SWG| Hayward Progrid pl-p-4 Computer | Hayward Pump and VS 2 HP motor | 2d, Fixed 2 HP pump waterfall and slide.
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    Re: So you want to add borates to your pool--Why and How
    Wow...pcmacd..what a fabulous idea..especially here in Florida with that storm (Debby -that won't LEAVE) to be able to use that water for cooking, maybe even drinking (if the power goes out and my well-pump goes off). Thank you...geez..why didn't I think of that? I filled some gallons with water...ha..who needs that?!
    Re: Suitability of pool water for personal ingestion
    This has come up several times before, with somewhat ambiguous results. See for example this topic.
    Mar 2007
    San Rafael, CA USA
    12,082
    And this topic as well. If you have a hot water heater, you should use that for drinking water first, assuming you don't have emergency bottles of water already available. Just shut off it's inputs (and gas, of course) in case the mains are contaminated. That should give you at least 50 gallons of fresh known good water.
    Aug 2011
    Central Valley California
    121
    My cats drink the pool water. It doesn't bother them.
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    Mar 2007
    San Rafael, CA USA
    12,082
    If you don't have any other water source, then drinking pool water is better than not drinking any water at all. The point was that if you have a better source of water to drink, such as a from a hot water heater, then you should use that first. It's not that pool water will be toxic and kill you, but rather that it isn't as good a water source as others because it is generally high in salt and possibly somewhat higher than drinking water in disinfection by-products (and borates, if you've added those).
    Oct 2010
    Mesa, AZ
    63
    Well, I used to use bleach as my chlorinator, and after a couple of years, one can, w/o a doubt, taste the sodium in the water!
    I expect that _salty_ water is better than none, but why not do better?
