Thread: Using Chlorine tabs in a saltwater pool?
    I have a chlorine generator that is not working and needs to repaired/replaced. Is it okay to use chlorine tabs temporarily until I get the generator fixed?
    AG 15x30 4 ft deep 12000 gal.
    Aqua Star 100lbs Sand Filter model fs019
    Installed june 2012
    30,414
    Re: Using Chlorine tabs in a saltwater pool?
    Bleach is better because it contains no CYA...what is your CYA level?
    If CYA is Cyanuric Acid level it is around 30 ppm. How much bleach should I use for a 9000 gallon above ground pool.
    Installed june 2012
    30,414
    http://www.poolcalculator.com will give you the answer to both chlorine or the tabs, whichever you choose.
    With CYA at 30 now, using tabs for a couple of weeks is just fine.
    Thanks
    Installed june 2012
