Results 1 to 15 of 15
Thread: Pool Robot Vac... Skimmer... Which, How, Both... LOL
    I have a Kreepy Krawly (sp?) vac and I'm very very happy with the way it is working. It really keeps the pool nice and clean.
    The problem is that I have to put it into the port inside the skimmer. There appear to be two "ports" in the skimmer. One has lots of suction, and one has nothing... not sure what that one should do.
    Anyway, when I put the Kreepy on the suction port in the skimmer the bottom of pool looks great... but there gets to be some **** on the surface of the pool that I don't like. If I take out the Kreepy, the bottom of the pool gets **** and the surface looks good.
    I (think) it could all be solved if they had installed a vac port on the pool, but this pool (in ground) doesn't have one...
    So... what (if there it's possible) is the solution?
    I'm new to all this, so don't laugh. LOL
    Many thanks!
    Pete
    16000 Gal. Kidney / Gunite / SE Florida / Taylor K2006 / Stenner
    Jandy CS100 / Sta-Rite U3 Skimmer / Pentair Great White / Single Floor Drain / Single Return / Hayward SP2300VSP
    I'm still learning and I know nothing!.. I'm loving the Stenner!
    22,544
    Re: Pool Robot Vac... Skimmer... Which, How, Both... LOL
    Hayward makes a vacuum plate with a diverter that allows flow into the skimmer and it's adjustable.
    I've been reading about these skimmer vacuum plates... and there appear to be few different kinds.
    Do you recommend a certain one?
    Also, what happens to the basket when you use one?
    Isn't it a trip-hazard... having this big things sticking out?
    Any ideas or thoughts?
    Pete
    22,544
    The one I have has a 90º elbow on it and the hose comes out the mouth of the skimmer so you cna put the cover back on the skimmer with it in place. So even on an inground pool it wouldn't be a tripping hazard. I can't recommend one but I believe they all work about the same and you probably won't go wrong with any of them as long as it fits your skimmer.
    The skimmer basket stays in place. I like better because it's easier to clean the skimmer basket than the pump basket and it's a extra level of protection.
    Understood. I'm going to take a picture of what I have and post it up as soon as I can.
    I really like the idea of the elbow that stays under the lid. Not sure how the strainer can stay in place since the hole that the vac. plugs into is under the basket...
    22,544
    With the vac plate you don't plug the hose into the skimmer hole, it plugs into the plate.
    Does the vac plate then plug into the skimmer hole?
    22,544
    If you look at the skimmer there's a boss where the basket sits. That's where the vac plate sits and the suction holds it in place.
    Hi! Ok! We've got pics and more questions!
    What's a "boss"?
    Should there be a "door" or "flapper" on the skimmer? Mine is just a rectangular pass-through without any kind of door or flapper... is this normal with a skimmer?
    Based on the photos below, can you suggest a vacplate that I can send the hose out though the skimmer and not have the trip hazard that I'm concerned about?
    Thanks for everything! Pete
    22,544
    The vacuum plate will sit right on top of the basket lip.
    Measure the diameter of the skimmer above where the top of the basket sits and you should be able to find one that will work.
    Here's one example. The one I use is for a Waterway skimmer.
    Sorry to sound like a dope... but how does that keep the skimmer working at the same time as the vac?
    My current vac plugs into one of the holes in the bottom of the skimmer well. (The one with suction, obviously) -- when I do this, it no longer skims the debris off the top of the pool. My goal is to have the robot vac work AND the skimmer yet keep the "workings" under the skimmer cap (or some other way to keep it safe so there is no trip hazard...
    What did I miss?
    Pete
    22,544
    It doesn't, but you can get one of These and it allows you to vacuum and skim at the same time.
    Yeah... only wife feels it will be a trip hazard with a 2 yo and a 4yo around... any alternatives?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Man it sounds like that is what you need, except you need the pipe for the cleaner to stick out of the skimmer opening. This one which is same as above appears not assembled in the picture, maybe it comes that way? They sell all the parts of it individually too. I wonder if you could change it with a 90 fitting so that it doesn't stick out of your deck and you can put the skimmer cover back on and route hose through skimmer opening. http://www.inyopools.com/Products/07501 ... tm#reviews
    Alternatively you could get a cheap skimmer cover to run the hose through (cut a hole in it with a holesaw) to close up the majority of the skimmer, you'd still have a hose exposed.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    22,544
    You can get it with a short stand pipe that can be adjusted low enough that it should fit under your skimmer lid.
