Thread: Insalling Poolskim - need to convert slip return to threaded
    nolefan's Avatar
    Jun 2011
    Ft. Lauderdale, FL
    19
    I purchased a "Poolskim" secondary skimmer. When I opened it I learned it needs to attach to a threaded return line. My returns are 1.5" smooth pvc and use a slip style eyeball to direct the water. Is there a way to convert a smooth pipe to a threaded one? It seems there should be a coupler of some kind that can glue into the smooth return line and have a threaded part to screw the poolskim onto. I just cant seem to find one. If anyone can point me in the right direction it would be appreciated. Thanks
    12,000 gal / IG: Diamond Brite / Pool Pilot Digital SWCG / SC-36 Salt Cell / Hayward 1 hp pump / Pentair CNC 100 / Solar Heater
    22,551
    Re: Insalling Poolskim - need to convert slip return to thre
    They make inside couplings. You could get one of those and a threaded adaptor and it should work.
    slip style eyeball
    I’m unfamiliar with this eyeball. Could you please post a photo of it, as well as how it ‘holds’ into the smooth return outlet? Whatever it takes to get the POOLSKIM operating is well worth it. My POOLSKIM has been an indispensable asset to my pool.
    Regards,
    -Gary
    12,000 gallon, tile finish, in-ground pool with spill over spa.
    Pump - Sta-Rite 1.5 HP
    Filter - Hayward Star-Clear C-1200
    SWG - AutoPilot Soft Touch
    Pool Skim
    Zodiac MX8
    BBB since 11/2008
    South Florida
    Jul 2007
    Hillsborough, NC
    525
    From the poolskim site here you can find the kit you need:
    http://www.poolskimusa.com/fittings.htm
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
