Results 1 to 10 of 10
Thread: Clarifier, or Floc?
    Clarifier, or Floc?
    Which should I use to help get out the cloudiness? I have clean cloudy water now, and I really really want to swim! Suggestions?
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    30,431
    Neither would be my first choice. I would first determine that there is no algae present which can, and usually does, cause cloudiness.
    Once you determine the organics (algae) are killed, I would then run the filter 24/7 'til the water cleared.
    Have you recently cleaned up your pool that was heretofore green? Does your pool hold FC overnight without dropping more than .5 or 1ppm?
    The flocculant or clarifier will not help unless you know for a fact there are no remaining organics.
    Mar 2007
    Texas
    444
    As Duraleigh said, 1st make sure your numbers look good and you have no algae. After it is determined that you have no algae and your numbers are good, I would go with the clarifier. I had this problem a couple years ago, the dead particles were to small to be filtered through my filter and made for a cloudy pool, I used the clarifier and in no time it was totally clear, Good luck.
    27' Round AG, 17,200 gallons, sand filter
    I am holding overnight, and actually not losing alot during the day, 1.5 PPM max during the day, and holding overnight.
    I did recently clean, but it is very much dead algae, it could not possibly have survived being at shock level for 4 days, could it?
    I think I mightl use clarifier, although I DID go out and get one of those filter bags, and it is catching alot of gunk. I can almost see a difference already.
    30,431
    First, nice work on the algae kill. That's not as easy as it sounds.
    Secondly, floc or clarifier may well speed up the clearing but I'll bet if you keep that pump running 24/7 your filter and the filter bags will do the same thing......perhaps take a bit longer.
    no, algae killing is not easy. It took e about 4 days, and unknown amounts of bleach, monitoring the FC, and TC every 30 minutes or so, backwashing, backwashing, backwashing and more backwashing.
    I decided to wait and see if the filter bags/pump do it quick enough, too cold to swim now anyway!
    I also swiped the new filter bag off DH's new saw....a miter saw, and it works as well, if not better than the filter bag for pools. Yeah, he isn't going to be happy, but oh well.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Quote Originally Posted by edbson
    Oh, you evil woman!
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    Apr 2008
    NC
    1
    Hi edbson- I use a flocculant called Cleansweep that I get at Lowe's when I need to clean up dead algae or just the winter's crud that the filter has trouble with. It costs about $10.00, and it's liquid, so it's easy to use. I just mix it in a pail of water and throw it out over the water, leave the filter on for two hours, and cut it off and let it sit for a day. Then I vacuum to waste (VERY slowly), and voila, clear water! I usually turn the pump off for another several hours after the first vacuuming, and then vacuum again. Yes, time consuming, but a much quicker fix than just waiting for the filter to do all the work. Good luck to you!
    "Don't just sit there- swim something!"
    Mar 2007
    San Rafael, CA USA
    12,082
    The AquaEZ Clean Sweep product is shown here. A similar product, that's more expensive but some people swear by it, is OMNI Liquid Floc Plus. Clarifiers and flocculants are not needed if one has a working filter, maintains shock chlorine levels, and has patience, but these products can make the process of clearing a pool go a little faster.
    Thanks, if adding more sand doesn't help I am gonna try that.......although vacuuming to waste is almost impossible( pool collapses after 6 inches gone)
