Thread: am i turning over enough water???
    Guest
    i think i did the math correctly but according to my flow meter my pump is moving 45GPM. i run my pump 24/7. again if my math is correctly. i did it this way 45 X 60 (45 GPM times 60 min) thats 2700 GPH, so times that by 24 (hours, i run my pump all the time) thats 64,800. thats JUST MORE THAN ONE turnover a day, i thought we were supposed to turn over atleast twice a day.
    or is my math completly wrong. im a science, history, english guy.
    Your math looks right.
    The usual design goal is to build a system that is capable of two, or preferably three, turnovers a day. But you normally only actually run the pump long enough to get one turnover per day.
    Guest
    The usual design goal is to make a system that is capable of two, or preferably three, turnovers a day. But you normally only actually run the pump long enough to get one turnover per day.
    so that goal was not made with my system then, as it takes 24 hours to turn over the entire pool, what fixes this then???
    30,419
    a full-rated 1.5 hp pump should be capable of at least twice that GPM. What's your filter pressure?
    Jan 2008
    Malaysia
    109
    Vince,
    If your 1.5 hp pump can only produce 45 GPM, you must be pushing your water through a survival training course. My 0.5 hp pump produces 44GPM and I run my pump 1 turnover a day (3 hrs). Thanks to my shed from the 80 degrees weather whole year round.
    Vincent.
    8,000 gal IG concrete & tiled lap pool, 1/2 hp pump, 24" sand filter, SWG Auto Clean, whole pool under shed, 3 X 2ft waterfall one end overflow the other end. TF100 Testkit. 80 F Water whole year round.
    Guest
    its an old pump, and its about 80 feet from the closest return. there are some pipes, not a mess load.
