Results 1 to 11 of 11
Thread: What's the point of those chlorine "puck" floating devices?
    All is great with my pool now. The black swamp is now crystal clear. the ph is spot, chlorine levels (avail, etc.) are all on spec... all is happy happy.
    The question I have is what the heck was I thinking buying those "tablet" "puck" type things??? (and the float that they go in)? Everything I read about them (here and other places) is that "type" of chlorine is bad because of CYA issues, etc. In my case, I don't understand the point of it at all.
    My avail. chlorine will go to zero (0) with the puck... the only way to get my avail. chlorine to where it needs to be is to add liquid chlorine.
    Ok. Make fun of me... what's the deal?
    Pete
    16000 Gal. Kidney / Gunite / SE Florida / Taylor K2006 / Stenner
    Jandy CS100 / Sta-Rite U3 Skimmer / Pentair Great White / Single Floor Drain / Single Return / Hayward SP2300VSP
    I'm still learning and I know nothing!.. I'm loving the Stenner!
    Apr 2011
    Lynchburg VA
    393
    Re: What's the point of those chlorine "puck" floating devic
    Most pool owners think those floating dispensers and chlorine pucks are the answer and have no idea what CYA even is. I dumped 150lbs of shock into my pool over a 6 month at the direction of the pool store before I learned about BBB and CYA.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    The Floaters with Pucks in them have some limited uses, even though the Pucks introduce CYA.
    1. Vacation Coverage - So long as you keep CYA at manageable levels, you can drop a Floater in when you will be gone for several days, so you don't come home to an algae bloom.
    2. Need CYA - It can be an effective method of introducing additional CYA while also chlorinating.
    We used the Pucks while curing a new finish until it was time to start up the SWG.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Ah! Understood. I'll use what I have (2 more pucks) and forget about the floater. I've been doing BBB and it's been terrific.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Quote Originally Posted by FixItPete
    Why not just save them for a long weekend when you're going out of town and can't add liquid chlorine?
    That's what I was thinking...
    Mar 2010
    Spring, TX
    1,082
    You can also use them if you have low CYA and want to bring it up while adding cholorine at the same time. Like me I could have used them since I have a CYA level of 30 want wanting to shoot to 50. But I chose to add granular cya.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    You could put some gems from a rock shop in it and when people ask you how your pool is so clean and sparkly you could show them the magic!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Quote Originally Posted by harleysilo
    I like this idea!
    38,290
    I think the idea is hilarious
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Using pucks works fine for some people. I never had a problem when I lived in New England. With a very short pool season, the water change from regular back flushing by the time CYA levels start to get out of hand, it's time to close the pool and drain a third or more of the water for winterizing. Snow melt draining through the mesh cover further dilutes things. By spring the CYA is back near zero, and you start over.
    chiefwej
