Results 1 to 7 of 7
Thread: What is this?
    What is this?
    There is this water supply line sticking out of the concrete apron near the shallow end of the inground pool. It looks like something screwed onto the top of it at one time. It feeds back to the basement of the house. When I turn the valve on water comes out of this but given its location I'm not sure what this is used for. Any ideas?
    Apr 2011
    Lynchburg VA
    393
    Re: What is this?
    Could this be a water supply line used to fill or top off the pool?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jun 2012
    western NY
    1,562
    Re: What is this?
    it probably had a 90 degree elbow on it at one time to direct water into the pool. It was most likely used as a refill point for the pool.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Re: What is this?
    perhaps but what would attach to it so the water would reach the pool? Wish I could attach a picture to show
    Re: What is this?
    Are refill lines ok to use in the NorthEast? Wondered about winterizing.
    Apr 2011
    Lynchburg VA
    393
    Re: What is this?
    As long as you can shut it off in the basement and drain the water out of the one you should be fine.
    Pool School
    Pool Calculator
    Test Kits
    Ft Lauderdale, Florida
    1,455
    Re: What is this?
    Usually a 90 degree elbow, and what looks like a bathtub spout, long enough to position over the pool...if it's a fill line.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
