Thread: Better CYA Test Kit?
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    Relationship between CYA and NTU
    I just ordered the Taylor 4088 on Amazon. I don't mind the increased reagent use since I have a 1 pint bottle of CYA reagent. I continue to have trouble getting consistent results with the standard view tube. I guess I'm an eternal n00b in this regard.
    21,000 Gallon IG Plaster with Spillover Spa (Built in 1978) | 48 sq/ft Hayward DE Filter | 3.0 HP Pentair Variable Speed Pump | Hayward H250FDN Heater| 8 Gallon Liquidator | Taylor K-2005 | Taylor FAS-DPD Chlorine Test | Taylor "SpeedStir"
    Re: Better CYA Test Kit?
    The tube with the movable black dot does have some advantages, though you can get almost as good an effect by simply re-pouring the regular test several times with the same water sample.
