Thread: CYA Levels
    Mar 2012
    Amarillo, Texas
    341
    CYA Levels
    My CYA level is 50 and I've been adding about 96 ounces of clorox a day to my pool to keep it on the upper end of the FC level. My pool gets full sun from about 7 a.m. to 9 p.m. every day. Would raising my CYA to 60 be beneficial?
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Jun 2010
    Glendale, CA
    513
    Re: CYA Levels
    As long you have a good grasp of the chemistry and how it works there really isn't any harm in experimenting with a higher CYA value and seeing if that cuts down on your chlorine consumption without any unwanted side affects. In hot sunny locations there's a case to be made for running higher CYA numbers - I personally run my pool quite a bit higher than the recommended values because it cuts down on summer time FC loss.
    BUT - I'm comfortable with my pool and happy with the results. For the uninitiated this may very well be bad advice - hence it's not really given.
    Worse case scenario is you find that you are constantly fighting a low level algae issue and you need to lower it again.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Re: CYA Levels
    Higher CYA levels tend to work just fine for a while, and then cause major problems. Going up to 60 is certainly safe enough to experiment with, but I would be very cautious about trying out levels above that.
    Apr 2011
    Lynchburg VA
    393
    Re: CYA Levels
    My pool get full sun most of the day and I have bumped my CYA up to 55 at it has worked out fine.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Re: CYA Levels
    Quote Originally Posted by mpacheco72
    FWIW, I have the same size pool as you, with only about 75% as much sun. My CYA level is about 70 (not by choice, I was using the pucks before finding this site). I am still putting in 80-96 ozs of 6% bleach per day to maintain my levels...
    bbb
    tf-100
    pool schooled
    18x48 intex ultra frame, 6500 gallons, stock pump and filter
