Thread: How can I eliminate the plunger valves on a Intex 24' round
    Hello everyone!!! I'm in the process of installing a new Hayward DE filter to my Intex 24' round pool, and also I would like to upgrade the plumbing to pvc 1 1/2 plumbing. My problems is that I need to eliminate the Intex plunger valve and replace them with regular ball valves. How do I do this? Thanks!!! There are some threads addresing this very same problem, but for some reason the pictures are not visible. Thanks!!!!
    Intex Ultra Frame 24' Round
    Sun-Heater 4'x20' Solar Heater
    Hayward EC-50 D.E Filter
    May 2008
    gulf coast of Texas
    166
    Re: How can I eliminate the plunger valves on a Intex 24' ro
    Oh...and where the hose popped off the return part...the water drained so quickly, that it actually washed away some sand next to the pool wall...there is a small gap and when I bent down to look...you can see where the styrofoam sheet sunk down a bit past the wall bottom. Now what?
    Julie
    Atlantic Pool Products "Prestige" metal wall pool 18' x 48" round
    vinyl liner
    Hayward Power Flo pump
    Hayward Perflex DE Filter Model EC50AC
    I replaced one plunger valve on the intake side and made a connector using and 1-1/2" PVC elbow, 1-1/2 to 1-1/4 reducer bushing , the Intex hose nut cut off their hose and a gasket from another Intex adapter.
    I hope this helps, there's always a rainbow when trying out smart those folks @ Intex. When I had some I was going to post the steps on how to build it (I need to make another one for my Solar panel hookup)
    Intex Ultra Frame 16 x 48, SWG - copper disconected, 2650 Sand filter, Intex PVC mods, Aqua Critter pool cleaner, ECO Saver Solar panels
    Zooduster, thanks for your response!! Hey do you have a solar panel heater in your Intex? Are you running the factory filter? Can you tell me how is the filter / solar panel.setup you have? I'm in the process of upgrading to a new Hayward AbG DE filter rated at 50GPM. And I also want to incorporate a solar panel heater heater with the new filter. But I'm not sure on how to connect it. Heater in line after filter??? Or separate pump dedicated to the heater? ?? Or zhould i used a diverter valve to divert some water flow to.the panels and tge rest back to the pool? ???? Sorry for my typing, it was from my cell phone.
