Thread: What's the consensus on Intellichlor IC40 cells?
    Mar 2007
    Murrieta, CA
    215
    I'm considering purchasing a new IC40, and I'm wondering if Pentair has resolved the problems with their older models. I see that Pentair now has a 3.1 firmware in their latest models. My last unit was a 1.9R. I'm wondering if the 2.x and 3.x models are considered to be more reliable than the 1.9 and earlier. I see a lot of posts with IC40 problems that are very similar to what I went through, but I don't see anything that discusses the differences between the different versions.
    For reference, here is a history of the problems I've had (details in threads below):
    My first cell lasted about 18 months (two season). It was replaced under warranty, but the replacement only lasted about 18 months as well (one season). I gave up and switched to liquid chlorine and tabs, which has worked just fine. I used liquid only for about 9 months, and have been using mostly tablets for the last 14 months. I have not had any problems with the pool during this time.
    My CYA is now in the 80-100 range, so I know that I need to do a partial drain and fill to bring it back down, but this wouldn't be necessary if I put in a new cell.
    http://www.troublefreepool.com/intel...bs-t30631.html
    http://www.troublefreepool.com/havin...in-t23137.html
    http://www.troublefreepool.com/probl...tup-t9849.html
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Re: What's the consensus on Intellichlor IC40 cells?
    Pentair had some surprisingly common problems a couple of years ago that are now resolved. However, no SWG is perfect and all of the brands, including Pentair, will always have problems occasionally.
    Mar 2007
    Murrieta, CA
    215
    Pentair has some surprisingly common problems a couple of years ago that are now resolved. However, no SWG is perfect and all of the brands, including Pentair, will always have problems occasionally.
    Thanks Jason. I understand that there's always some type of failure rate, but the problems with the 1.x units seemed quite excessive. I suspected that there might be some type of quality issue last year, so that's why I put off buying a new unit. Do you think that the newest units are now considered reliable enough to actually get near their 8000 hour rating?
    I'd appreciate it if anyone with 2.x and 3.x units would chime in here.
    tjwaggoner's Avatar
    May 2012
    Ashland KY
    88
    Not sure the firmware on mine (IC40) but assuming its the latest as it was manufactured in 4/12. Obviously have not had it very long but I can say that I have had exactly zero issues with it since the first time it was switched on. I run it and my pump on the same switch 24/7 with the IC40 at 20% (wish I could go a little lower as my FC stays around 7ppm with a CYA of 35-40). I hope I get 5 seasons out of it but for time and effort savings with my pool its work the ~$500 for a new cell every 3yrs to me. I went into it not planning on a SWCG being any kind of a money savings and I am pleased with the ease of pool maint. I test my water every few days and everything seems to just stay right where it needs to be.
    10,000gal fiberglass kidney
    3/4 hp whisperflo
    Sand dollar SD80
    IC40 SWCG
    (2) PAL2000 multi colored LED lights
    all 2" plumbing
    no water features/no spa
    TF Testkit
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Not sure the date of mfr of my IC40, but it's been in my pool since August 2010 and to-date, I've had no issues with the SWG generating chlorine and functioning properly during the season. It's on it's 2nd season. I'm very happy with it and will probably replace it some day with the same.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
