Thread: Muratic Acid
    Muratic Acid
    I just added Muratic acid and did a test of my TA right after that. The numbers seemed way off? Did the acid screw up the test or something?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Re: Muratic Acid
    You need to give the acid 30 minutes with the pump on to mix into the water before doing any testing. If you didn't do that the reading could easily be off.
    Re: Muratic Acid
    Thank you very much Jason!
    Bel Air, MD 21015
