Thread: Easytouch 8 and gas heater settings
    May 2011
    No. CA
    111
    My heater isn't working, and I'm not sure if I messed up a setting on the easytouch when winterizing or...
    Easytouch 8.
    Laars Lx400.
    There is a heat pump setting on the easy touch showing disabled, but I didn't remember disabling it.
    Does the heat pump need to be enabled for a gas heater to run?
    tnx in advance.
    Pool IG 17,000 gallon (33 x 16) Spa IG 700 gallon - under renovation
    Sta-Rite IntelliPro VS 3050, Pentair Easy Touch 8, Intellichlor IC40, Pentair FNS Plus 60, TF-100 Test Kit w/ salt test
    Pentair Intellibrite 5G Color LED, Polaris 360, Lars Lx400 NatGas heater, Fafco Solar panels
    Re: Easytouch 8 and gas heater settings
    If you have a gas heater, heat pump should be disabled. Heater needs to be enabled on the HEAT menu, but heat pump should be disabled.
    May 2011
    No. CA
    111
    Thanks Jason.
    I found a broken wire going to one of the lugged connectors inside of the Lx400.
    Spa will be hot tonite!!
