Results 1 to 8 of 8
Thread: Painting PVC pipes
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    Painting PVC pipes
    I'm installing solar panels on the roof of my house. The feeding and return pipes are the standard white PVC stuff.
    For aesthetical reasons, I'd prefer to have them black, like the rest of the panels.
    Any suggestion on which type of paint would best stick to the PVC pipes? Should I do anything special to prepare the surface?
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    did a quick search and found this
    How to Paint PVC
    they recommend Krylon Fusion
    K HOLMES
    23 X 45 GUNNITE
    OWNER/BUILDER
    Rocklin, Ca
    467
    Where did you buy the solor panels? Do you have any pics?
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    Quote Originally Posted by cobra46
    I don't have pictures since I haven't installed them on the roof yet. I'm doing the plumbing first.
    The brand of the panels is Technosolis and they are made in the US (I think they have a plant in Canada as well).
    I ordered them and the Aqualogic P4 controller from www.heatwithsolar.com . They had decent prices and free shipping.
    The owner, Stephen Cumminger, seems to be passionate about everything solar. He's been very helpful and answered all my questions very quickly. One of the panels was damaged during shipment and he offered replacing it for free (without me even returning the damaged panel). At the same time, the manufacturer offered the same thing (free replacement panel). I ended up getting it from them. I thought that was pretty good service from both the vendor and manufacturer.
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    Quote Originally Posted by hanau
    Seems like light sanding with a sanding pad and Krylon Fusion paint is the answer.
    Thx.
    Jun 2007
    Poughquag, NY
    217
    Painted some of my solar PVC with black Fusion. Didn't sand, I did wipe with PVC cleaner (yellow can stuff). Works well so far, heading into 2nd season (maybe 18 months). I would recommend painting before installing if at all possible, the 2nd story roof can get pretty scary!
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
    Mar 2008
    Maryland
    56
    I've had customers use regular exterior spray paint on their pvc to blend their lines into their landscaping. No prep is really necessary besides cleaning the pipes.
    Jan 2008
    Forney, TX
    162
    Paint is actually a good idea because if PVC is left exposed to the elements it eventually gets that chalky look. You've probably seen old PVC that's been outside for years and you touch it and it leaves a white residue on you? Paint will protect the PVC from UV rays and prevent that.
    Our pool adventure... click here
