Thread: Been Doing My Homework!
    Apr 2009
    Louisiana
    64
    I posted a couple of weeks ago with high CYA levels & having several slick spots in our pool. Since then I have been testing, reading (and reading ....lol) pool school & am just now beginning to understand why & how - I hope - to balance my water. Not to say it is balanced. My test this morning:
    PH 8.2
    FC 2
    TA 90
    CH 160
    CYA 35
    Salt 2200
    The pool calculator tells me to lower my PH to 7.5 I need 29 oz. of muratic acid, to raise my FC to 4 I need 79 oz. bleach, CH to 260 - 281 oz. calcium chloride, CYA to 70 89 oz. of stabilizer & 3 bags of salt to get to 3200. i know when I add more salt, my chlorine will begin to move up.
    Can someone please tell me if this is correct & which order I need to proceed in? Thanks so much for your help.
    19,000 IG Pacific Blue plaster,raised spa with spillover,rock waterfall, Jandy 2.5 HP pump,Pentair sand filter,Paramount in floor cleaning system, Jandy Aquapure SWG, Aqualink remote
    Re: Been Doing My Homework!
    Lower the PH right away. The next most important thing is to start/continue raising CYA. Then work on salt. CH is next. Adjust FC after sunset if practical.
    One thing to watch out for, the SWG should be off for 24 hours starting just before you add salt. Because of that you will probably need more chlorine than you calculated.
    Apr 2009
    Louisiana
    64
    Thanks Jason! Will add MA right now then stabalizer. Can I do this all today?
    30,431
    One after another is fine but not simultaneously. CYA will not register on test for maybe a week. CH may take a while to dissolve and register. You will see pH change within an hour....FC within an hour, also.
