Thread: Is HTH DE filter aid the same as regular DE?
    Have been advised to add some DE to my sand filter. Our local store has HTH DE Filter Aid in 10 lb and DE of another brand in 25 lb box. I would rather have the smaller container, but can't find out whether the Filter Aid is the same as regular DE, or if it is ok to use for this application.
    21 x 41 above ground, vinyl, with deep end; 28,000 gallons; AquaView 24" sand filter, 2 hp pump,
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Is HTH DE filter aid the same as regular DE?
    Yes, that is what I use.
