Results 1 to 7 of 7
Thread: borax via skimmer
    Diver's Avatar
    May 2011
    South of Boston
    450
    borax via skimmer
    bad idea or not? how about boric acid?
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Jan 2010
    Randleman,NC
    620
    Re: borax via skimmer
    Very simple just had everything straight to the pool water..I just pour mine straight from the return so it get's spread out into the pool.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    30,133
    Anything can be introduced into the pool via the skimmer. It simply depends on how fast you add it. Plopping 20 lbs of Borax all at once in a big glop is a no-no. Putting it in slowly so it doesn't clog up the skimmer is just fine.
    In some ways, the skimmer is better than allowing some things to settle to the pool floor.
    Diver's Avatar
    May 2011
    South of Boston
    450
    that's exactly what i was thinking. thank you.
    And conversely adding some things to the skimmer, especially too quickly can cause trouble. Remember that there is a long pipe and also pump/motor attached at the other end of the skimmer.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Jan 2010
    Randleman,NC
    620
    Adding to skimmer..I have to agree..I think you get a quicker chemical response adding it straight to the water itself at the return.Anything you put down the skimmer has to be filter'd so it take's away from the chemical add itself.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I add mine slowly to the skimmer, no problems.
