Thread: Toxic Public Pool Sends Kids to Hospital
    http://shine.yahoo.com/parenting/toxic- ... 00789.html
    One mom on the scene described "an explosion of acid" rising from a once serene pool, though it's unclear what officially happened around 2 p.m. yesterday to sicken as many as 80 people, according to the Star's estimate.
    "We haven't reached a final determination on the cause of yesterday's incident," John T. Althardt, spokesman for the Marion County Health Department, told Yahoo! Shine Friday. The pool employee on the scene that day might have more answers, but is still recovering in the hospital along with six other patients being treated for respiratory distress.
    For now, it's believed a toxic mixture of chlorine gas caused swimmers, most of them children, to suffer bouts of vomiting along with eye and lung irritation. Lt. Derrick Sayles of the Indianapolis Fire Department points to ACID Magic, a pool sanitizing solution that if imbalanced can produce a potentially dangerous level of toxicity.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Toxic Public Pool Sends Kids to Hospital
    I saw that story this morning. Guess we will have to wait and see what caused this to happen.
    It does bring to mind an important safety guideline: When adding 2 or more chemicals to a pool, always add them separately - never combine them "to save time".
    Jul 2011
    Huntsville, AL
    96
    Quote Originally Posted by Kathi52
    I posted about this yesterday but the entire thread was removed. Guess it just goes to show you that TFP doesn't want anyone speaking ill of using bleach! Because that is what they were using!! And it was based on operator error. Even so, I would never want my kids nor any other family member swimming in GALLONS of household bleach! It was accident just waiting to happen and it did...going on the cheap doesn't always pan out!
    According to the article the fire dept blames the improper use of "acid magic", a muriatic acid replacement as the culprit. Any chemical improperly used in high quantities is bad.
    http://www.google.com/search?hl=en&gl=U ... acid+magic
    I'm not sure how acid magic differs but i do know from personal experience that once the lid is removed off of a muriatic acid container that if you are too close to the fumes/gas will absolutely make you gag. Now imagine that in high/improper quantities.
    edit-both muriatic acid and acid magic are diluted concentrations of hydrochloric acid. Acid magic adds buffers of some sort.
    Sent from Samsung Fascinate running ICS.
    18x36 IG Vinyl 23,000 gal, AO Smith 48Y 1hp pump, Jacuzzi Laser Sand Filter 250L, T104R, K2006, Polaris 280
    SE Minnesota
    91
    Well, then you best not let your kids swim in any kind of pool and stick to lakes and rivers. Active ingredient: Chlorine = Sodium hypochlorite, Bleach = Sodium hypochlorite. No matter what you call it, it is the same. You just may get it in different concentrations say from a pool store compared to a grocery store.
    Mona SE MN
    24' round 48" high AG
    Meteor Sand Filter
    1.5 HP pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Kathi52 has her own anti-chlorine bleach agenda that she has advocated the entire time she has been a member of TFP. We can back up our position with solid scientific studies where as Kathi52 resorts to emotional prophesies and biased quotes from sales fliers to support her claims. By the way, her Permasalt system also uses chlorine. Activate, their twice monthly shock product is dichlor 45% available chlorine!
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    There is a home for such threads called Agree to Disagree so unless the thread was violating forum rules such as promoting products, being rude, etc. then the thread should have been moved, not deleted, so I suspect it violated forum rules.
