Thread: Out of town - in laws don't know bbb
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    My father-in-law has not yet moved in to his house. I'm maintaining the pool. He is there most days but has not yet learned anything about the equipment etc. My plan (already in progress) is to crank up to nearly mustard shock levels (23.5 ppm) since I was already shocking and not have him worry other than skimmer net and basket. I will be back Monday night. Losses most days run around 6pp
    When used and less when not used (as expected this weekend). That should keep it shocked for a couple days and drift down to normal range around the time I can look it over again.
    Does this seem reasonable?
    Fc:23.5
    Cc:0.5
    Ph:8 (7.5 before high chlorine so this is assumed false reading)
    TA: 175
    Ch: 350
    Cya: 40
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Out of town - in laws don't know bbb
    UnderWaterVanya:
    I take it that you dosed with chlorine Friday night (6/22) and I'm assuming you do not have a cover. If that's the case, then your approach should work based on your expected daily FC loss. I would test FC level on Monday night before adding any chlorine to determine what the actual FC loss was during the three days. Then you can fine-tune your chlorine addition. It is always best to use the amount of chlorine you need to maintain proper sanitation without needlessly overdosing. If FC loss is less than 6 ppm (based on no pool usage), you could likely go with a lower dosage than mustard shock level if you need to go another 3 days between checking. I would not go above mustard shock level in any event.
    If you do have a cover, the consensus I have seen on this forum is that dosing up to regular shock level and keeping the pool covered is usually good for a week with no further attention.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    I have a similar situation coming up ... 7 days away.
    My plan was to have my daughter add bleach daily ..... and give her a simple chart to determine how much based on amount of sunlight / clouds each day and how much of the day she has the solar cover on.
    So for example a cloudy day when the cover stays on all day i will have her add enough to add 1 ppm ..... on a day with full sun with the cover off i will have her add enough to add 3 ppm which is my maximum loss per day. I plan on starting 2 or 3 ppm below shock level when i leave.
    I would imagine the same thing could be arranged with a willing neighbor .... especially if the cover were left on because no one was using the pool.
    Not trying to hijack your thread but this was my idea and i figured i would see if it might work ... for you or just in general??
    Or in my case my CYA is in the low 30's .... would a week with 3 pucks raise it much??
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Three 8 oz Trichlor pucks in a 21,000 gallon pool would raise CYA by 4.8 ppm, per Pool Calculator. For Original Poster's (OP) pool size (13,500 gallons), the same dose would raise CYA by 7.4 ppm.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by BoDarville
    UnderWaterVanya:
    I've tried to confine myself to my original thread located here: cloudy-but-i-think-i-m-on-the-right-track-newbie-t47425.html
    Essentially, yes I did as you thought. I was gone an extra day and had him dump 96oz of 6% bleach on Monday night blind because I was not able to be there until Tuesday evening. Tuesday evening I returned to FC of around 3-4ppm which was lower than I was expecting. Story since then is in the other thread. I'm still not sure I'm fully done shocking and thinking of doing another OCLT to be sure.
