Thread: Well, here is my question
    Dec 2007
    Central New York
    504
    Getting ready to install a new Hayward filter. Do I add 20% pea gravel or not?
    It's a 26 inch, 350 lb sand filter.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    30,419
    I struggled with the same decision. It makes pretty good sense but I called a couple of PB's in my area and neither of them ever did it so I followed them.
    My filter functions just fine but I still wonder. The triton paperwork says its optional.
    The large commercial filters almost always use pea gravel. Supposedly you get slightly better flow without any loss of filtering. Pea gravel is also cheaper than sand. I have never tried it myself since I don't replace the sand.
    Mar 2007
    Morris, IL
    477
    One of the advantages I could see to doing that is that the pea gravel would surround the lateral fins and keep sand from infiltrating into your pool in the event that a crack were to occur somehow. I don't imagine that it would affect filtering at all. I sort of like the sounds of it, and if I were to do it again I would probably do it, especially since I do get what appears to be sand on the bottom of my pool after the return line. I am not positive though, I vacuum and it goes away. It is not really that big of a bother to me, but if it gets worse I may just have to shop vac out the filter and see what is up.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
