Results 1 to 13 of 13
Thread: Finally got TF Test Kit!
    May 2012
    Illinois
    16
    I just got my TF Test Kit today and did my first testing tonight.
    FC - .5
    CC - 1
    PH - 7.5
    TA - 280
    CH - 250
    CYA - 40
    Since my CC was 1 and my FC was just .5 I started shocking. I added 186 oz. of bleach and 22 oz. of stabilizer to get my CYA up. I need to check my FC & CC in another hour and if FC is down I need to add more bleach to keep it at 16 for shock level. Is this correct?
    Chris
    Intex Ultra Frame 16' x 4', 5000 Gallon
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Re: Finally got TF Test Kit!
    Yes. Keep the FC level up.
    It's too bad you already added the CYA, because as the CYA level rises, so does shock level. If it's tied in a sock, pull it out and put it in a plastic bag until the shock process is done, then hang the sock again.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You have it correct. If you want, do a OCLT tonight to see where you are.
    May 2012
    Illinois
    16
    I never even gave it a thought about waiting to raise the CYA! I knew it was low and was worried about getting it where it should be. MY TA is also high, but my PH has been holding steady at 7.5. Should I try to get the TA down yet?
    Chris
    May 2012
    Illinois
    16
    just did a retest - FC is 17 and CC is still 1. Will check again first thing in the morning. Should I be taking my solar cover off while doing this?
    Chris
    38,275
    I don't think the cover matters for the OCLT, but during the day the sun would help break down the cc.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    May 2012
    Illinois
    16
    New set of numbers this morning:
    FC - 6
    CC - .5
    PH - 7.5
    CYA - 90
    Does everything look good? I think the CYA might be a little high.
    Chris
    30,419
    It is. You need to drain/refill about 50% of your water to get the CYA down around 45-50 so you can manage your pool much easier.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    At 11:15 last night:
    Quote Originally Posted by cdereu
    Then at 9:10 this morning:
    FC - 6
    A loss of 11ppm over night?
    That's a GINORMOUS hit, and I find it nearly impossible that you lost that much FC and CC remained below 1 (To be honest...with that much loss, I'd find it difficult to believe CC was below 10). Is the 6 above a typo for 16 perhaps?
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    May 2012
    Illinois
    16
    I thought 80 was the max CYA for a swg? Do I really need to drain 50%? I will retest my FC - I could have very easily figured wrong!
    Chris
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Looking at your cya numbers, going from 40 to 90 ppm is very unlikely unless you used a lot of liquid stabilizer. Are you having problems with the test?
    You need to know this number in order to properly shock.
    If you put only pool water (no R-0013) is the dot visible when the tube is full?
    38,275
    did you use liquid or solid CYA? Review the extended test directions to verify you are doing the test correctly .... It is a sticky in the testing forum.
    You should not need to drain that much since you have a SWG. But it will require much higher FC levels for the required shock process.
    30,419
    I carelessly overlooked your SWG. I would get CYA to 60-80 but draining to 40-50 is certainly not necessary.
