Thread: Thanks....
    Thanks....
    Just a quick thanks to the many posts that I have read over the past week while I tried to correct my pool issue. I invested in a DPD kit, not the recommended one, but that is another story. I fought with the pool for nearly a week...several trips to the evil stores, more water tests, they used the same strips that they sell there customers and no luck.
    One water test done on my own, downloaded the iPhone calculator app (wish it were an iPad app), bought some very expensive chemicals at Walmart (BBB) .... and the water is crystal clear.
    Now I just need to figure out what to do with that Nature 2 cartridge I hooked up before I read about the problems they can cause. I had used it in the past with relatively good luck, but the cartridge alone will just about pay for the new chemicals for an entire season for this pool.
    13,500 / AG / Vinyl / Hayward 150 sq ft Cartridge / 1HP 2 Speed / Born in 2009
    Intermatic Timer / Stenner 10GPD + Woods Timer / Former LQ (3/8 upgrade and SMC Valves) 2012
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Thanks....
    Welcome to tfp, Mwjman1
    22,550
    Re: Thanks....
    Welcome to TFP.
    Just don't buy the refills for the Nature 2. You can remove it next time you do any plumbing work.
    30,421
    Re: Thanks....
    The exchange rate between Nature2 cartridges and adult beverages is quite favorable as well.
