Thread: Is it possible to calculate volume if my pool is irregular
    Is it possible to use the Pool Calculator to calculate the pool volume if my pool is irregularly shaped (i.e., shaped like a bean)? I looked at old pool documents, which states that the perimeter of the pool is 80 feet and the depth of the pool is 8.5 feet. Will the "round pool" estimation work for my pool? Is there any other way I can calculate this?
    I want to put some chlorine into the pool, but I'm not sure how much.
    Please help this newbie.
    22.5K gal vinylpool -- Tagelus TA-60/60Dsand filter -- Hayward 3/4HP uprate Super Pump
    Apr 2011
    Seattle
    31
    Re: Is it possible to calculate volume if my pool is irregul
    I'd use the oval calculation to start and test again after the addition to test the volume estimate.
    20k gallon free form plaster pool with a spill over spa, sand filter, Master Pools in floor cleaner, Jandy PDA and Jandy Lite2 natural gas heater.
    Try a search for pool volume calculator. One will give you irregular shapes and how to calculate. I used one but unfortunatly I didnt save it.
    Sorry.
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Car_e
    If you want measure your pool, you can post the dimensions and we can help estimate the volume. A drawing would be great, but a picture might work too.
