Thread: Evapotranspiration sprinkler controllers
    Aug 2010
    Dallas, TX
    4,052
    Looking for some experienced opinioins on evapotranspiration sprinkler controllers. I have a 1.25 acre lot, and with temps already predicted to be 103 next week, I know my water consumption is about to go up. For example, July of last year saw a 150,000 gallon usage to keep the lawn green. I would like to find a system that has the ability to just water as much and when needed.
    Jun 2010
    San Antonio
    424
    Re: Evapotranspiration sprinkler controllers
    I recently installed the Hunter X-Core Controller and the Solar Sync sensor. It is working great and was the most economical smart controller I found.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
