Results 1 to 9 of 9
Thread: My water is cloudy, and need some advice please
    my pool water is cloudy. I'm trying to figure out why? I brought my FC level up to 8 or 9 (i will test when i get home) the day before when the water was clear and now it is cloudy. I think my CYA level is about 30ppm and my ph is around 7.5. Any thoughts on why it is so cloudy?
    -J E F F-
    Intex 14' round 48" deep above ground pool
    HTH 6 way test kit
    Intex Krystal Clear Sand Filter 1600g/hr
    I live in southwest Missouri
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Re: My water is cloudy, and need some advice please
    Did you use calcium hypochlorite to raise your FC? I used to use that to shock my pool and it would turn cloudy.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    It would help a great deal if you could post a complete set of water test results.
    Not sure what my alkalinity is but my levels are:
    FC 2.5ppm
    PH 7.5
    CYA 30ppm
    Yes I do use calcium hypo. I just added 2ppm of chlorine so it should raise it to 4.5ppm
    -J E F F-
    HTH 6 way test kit
    It would be really interesting to know your TA and CH levels. That would tell us if it is calcium clouding or not.
    If it is calcium then will the level deplete over time?
    -J E F F-
    HTH 6 way test kit
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    No. Once calcium is added to the pool, the only feasible way to get it out is with a partial drain and refill. The cloudiness will probably subside if you keep your pH in check, but the calcium will remain in the water. Adding a bag of shock will not raise the CH that much, but if you continue to use cal hypo as a primary source of chlorine, then your CH will continue to rise.
    Intex SWG
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,078
    Have you checked your CC levels?? Often cloudy water is a sign of algae.
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    I have a 16' x 48" pool - My water got a little cloudy with a really slight bit of algae and I did the unconventional thing to do.. took a mop around the pool and mopped where the algae was forming (it was a little slick there, so I loosened it up with the mop) poured about 2 cups of bleach and ran the pump for 12 hours, SWG for 4. My water is crystal clear. yay!!!! I'm ok for now I guess.
