Thread: Replacing top rails or cap
    I need to replace my top rails on my pool but don't know who the manufacturer is of my pool. I'm the third owner and in guessing it is about 6 or 7 years old...only guessing. Where should I start looking? thanks
    Tracy K.
    AG Vinyl liner - 13,000 gallons - 21" Sta-Rite Sand Filter w/ Hayward 1.5 hp pump - Installed 5/2010
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Replacing top rails or cap
    Welcome to tfp, kas
    If you post some pictures of the pool and the parts you are looking for, maybe someone on here will recognize it.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Be sure to include close ups of the top seat rail, the cover between the top rails and a good shot of the risers including the pattern on the side of the pool. The liner in the pool and the pump & filter do not typically come from the pool manufacturer (except Intex and the like).
    I have noticed, many pools look close to each other until you start looking at the details. I have a resin top rail and found there was lots of information about the manufacturer (and when the pool was manufactured) molded into the underside of the part. To get this, you would need to remove the caps between at least two rail pieces. Removing this much of the top rail is safe to do with the pool full.
    This is kind of what I am talking about. I took this picture to show my liner to another poster here at TFP so the focus is on the liner but you get the idea. My pool is an Aqualeader Concerto from 2004.
    -- Guy --
