Thread: what to do with used Muratic Acid?
    Derry, ME
    19
    Is it OK to just dump it down the drain and run some water?
    I used it to acid bath the filter fingers.
    15x30 Esther Williams semi-inground
    Hayward DE filter with 1/2 HP super pump
    4 2x20 Sungrabber solar panels
    TF100
    22,542
    Re: what to do with used Muratic Acid?
    If your drain contains metal pipes you need to dilute it a whole lot before pouring it in the drain. In fact I would pour a very thin stream down the drain as I ran water after I diluted it.
    30,403
    I believe I would pour it in the ground away from valuable plants or grass....it will quickly neutralize.
    Save it and use it to lower your ph When needed
    2008 23K IG Liner, Pentair intellipump vf, 48DE filter, Heatpump, SWC, aquabot turbo T, K2006 Testkit
