Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Leveling - help
    May 2012
    Phoenix, AZ
    17
    Leveling - help
    We've been trying to level our ground now for 2 weeks.. We are in AZ so the 110 degree isn't helping us finish fast. We put the pavers in and they are all leveled around to each other. We have wet the ground and placed a board on it and started walking back and forth on it to compact it. Only thing that still scares me is if I step right next to the paver the ground sinks in a bit still. So if it gets wet.. I'm guessing it might all sink together again. . I don't know what else to do.
    16' x 48" Intex Ultra Frame Pool
    Intex 2650 gph Sand Filter Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling - help
    Where the pavers that are sinking, did you happen to build up that area? When leveling you always want to dig down to the lowest point of undisturbed soil...never add or redistribute.
    May 2012
    Phoenix, AZ
    17
    Re: Leveling - help
    The paver itself aren't sinking. It's the dirt around it when I step over it. Holes were dug out to fit the pavers in.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling - help
    Was the dirt around it ever added to, or did you dig down to it?
    May 2012
    Phoenix, AZ
    17
    Re: Leveling - help
    No dirty added and didn't dig down. We have been watering the groud and stepping on it so it can compact. The inside part is hard like a rock.. but the outer part isnt. Hubby is done with the pool. Trying to find an easy solution because I won't have a pool come past Sunday. He will not help anymore.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling - help
    Is it only squishing when it's wet? If so, you should be okay. I would think since you did not add soil there, it most likely will work.
    It looks like you are putting up an intex type metal frame pool? If so, you might want to consider extruded polyethylene insulation sheets under the pool (and support posts) that would protect the liner from the edge of the pavers if the grounds sinks slightly once the pool is filled.
    May 2012
    Phoenix, AZ
    17
    Re: Leveling - help
    Yes it is a 16' x 48 ultra metal-frame. Okay, I can do that. Do I have to cut a hole where the legs will sit or place them ontop of the sheet.
    May 2012
    Montville NJ
    545
    Re: Leveling - help
    Quote Originally Posted by Sugarme
    Save yourself a lot of time, and a lot of heartache when the ground sinks some more after you put the pool up. Go to your local tool rental shop (even big orange) and rent a vibratory plate compactor. 1 hour with that will do more than "wetting and walking" will do in a month.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling - help
    phonedave's advice is also good.
    Some poster's on here have put the legs right on top of the foam. I suppose you could cut out for the legs, but then there may be some slack in your liner sidewall.
    May 2012
    Phoenix, AZ
    17
    Re: Leveling - help
    Okay thank you. I will try that on Sat.
    Leveling - help
    We rented a Toro Dingo from a hardware store. Under $150 for 24 hours ( delivered it & picked it back up for us) Rent the bucket attachment ( the Dingo is like a walk behind bobcat) borrow or rent a laser level. Without a laser/dingo tool combo, this will drag on and on. Plus you can do it all yourself.
    12 X 24 Solar Fanta-sea AG, Hayward, Sand
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Leveling - help
    I have this question in the back of my mind... if the outside area of the pool is where you are getting it wet and squishing in the stones... are you wetting the "hard as concrete area in the middle that same amount or are you just wetting the outside ring?? If you have a wet ring and a dry middle that is hard as concrete, it may simply be that outside are is wet and the middle is not.
    I ask because my "dirt" in my back yard will get squishy wet and things will sink into it; but, if left to dry it will set-up like concrete to the point where a maul or pick-axe will bounce off it only making little "chips" of dirt and a 3/4 inch deep hole.
    -- Guy --
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling - help
    I don't know if this is where techguy was going but...if it is squishy only when wet, that is normal for many soils. As long as the "squishy" dirt truly is undisturbed/unexcavated soil, then I would think installing right on top (with a tarp maybe) would be fine. The patio blocks will spread out the force on the ground below them, so even if the ground got temporarily saturated, I would think the distribution of weight there would keep the post from sinking.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Leveling - help
    Yes, Linen, that is where I was going. if the entire area gets the same amount of "squishy" when wet evenly, the 40,000+ pool is going to squish itself to a happy spot if the ground is a little squishy. If the ground is hard and dry (and level) when you setup the pool, the area under the pool is not likely to get very wet.
    I am going to make a guess here but once the pool is set and the the ground under the pool has dried as much as it will, the load on the legs is not huge. In a "bag pool" like Intex pool, the majority of the structural strength of the pool is in the bag/liner. The legs are there to stabilize it and keep the liner's top edge up above the water level. The pool is sort of like a big water balloon and the legs keep the "balloon" from rolling.
    -- Guy --
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling - help
    Quote Originally Posted by techguy
    That is my experience/understanding as well. If you liner is pulling significantly down on the legs, you did not install the pool correctly.
    May 2012
    Phoenix, AZ
    17
    Re: Leveling - help
    We are wetting the whole area the same. I'm thinking the area around the pavers are sinking because they dug out to put the pavers. I'm not really sure but I will keep compacting the dirt around it tonight and tomorrow. Hopefully I should be okay. I was also thinking of puting rocks around the pool when I'm done. I seen a couple of pictures here that people do that. Wondering if that would keep the ground by the pavers a bit dry. Last time I had the pool up. The kids were splashing so much water everywhere that the poles started sinking. That's when we took the pool down.
    I will get that plate compactor hopefully tomorrow but I had a question. If the soil around the pavers is my problem can I use the compactor to go over the pavers?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling - help
    Didn't know you already had a problem. Were the pavers actually sinking?
    If there was significant digout below the pavers,which I doubt, then it could be your problem.
    I think that would work, I know that is what is done when doing paver stones for driveways, etc.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Leveling - help
    You could try adding some pool base or other "compacting" rock under the pavers and compacting the paver and rocks into the soil until the base and paver no longer compact into the soil. Compact the paver until it is level with the others. I know this is not best, but it may be a workable solution.
    You could consider adding a "skirt" of landscape plastic around the perimeter of the pool. If you placed a foot of the plastic into the pool area (under the pool liner, under the pool legs, over the pavers) you could then add landscape rock over the landscape plastic once the pool is filled and settled.
    I know I have one riser on my pool that is a little lower (0.5 inch) than the other 25; but it's been fine for 7 years... so I left it alone when I changed liners.
    -- Guy --
    May 2012
    Phoenix, AZ
    17
    Re: Leveling - help
    Quote Originally Posted by linen
    Sorry I hope I didn't say it wrong. What I ment was that I had the pool up before and it was just on the ground with no pavers. But once we noticed that the legs were sinking we took it apart and put in the pavers. We have not set up the pool yet because we are just making sure everything is good this time before we fill up.
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling - help
    I think the pavers should fix the issue then.
