Results 1 to 8 of 8
Thread: Standpipe open at bottom?
    Hi - I'm new here but I'm quickly finding my way around. I appreciate having access to such a helpful site.
    I have a Jacuzzi LaserJet sand filter and I had sand returning to my pool. Since it had been a while since the sand was changed so I changed out the sand. While doing so I checked the laterals which were fine, but noticed that at the bottom of the standpipe it was completely open. Does this rely on pressure applied to the top of the standpipe to keep it seated at the bottom of the filter, or is there supposed to be some kind of covering on it? I ask because I put in the right type (#20 pool sand) and the right quantity and it is still blowing sand back into my pool. Not just a little sand -- I think I'm up to one of the 50 pound bags I just got through putting in the filter.
    As a additional question - does anyone have any good tips on getting the sand out? I don't know if it will torture my pump to run it through to waste, and a shop vac is out because of the depth of where most of the sand is (about 10 ft deep).
    Dawn
    24,000 gal inground plaster pool
    Jacuzzi l250 sand filter
    Hayward 1 1/2 hp SuperPump
    Hayward H250 electronic heater
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Standpipe open at bottom?
    I have one of those filters sitting open a home right now, so I can check tonight about the opening. I pretty sure it needs to be closed, unless it seals reliable to the bottom of the housing some how that I don't rememeber. Like I said, I can check tonight.
    I would just vac to filter since that is where you want it anyways...unless it is a whole bunch...more than your filter should hold. I have vacuumed sand many times with no appreciable negative effect on my pump. I would probably do it slowly, i.e. dont plunge your hose into a pile of it, but approach from and edge slowly.
    Qwaxalot's Avatar
    Jun 2012
    439
    This is a common problem with the Jacuzzi laser filters. The solution is to extend the stand pipe. If you don't know what this means, replace the filter, as you cannot replacement parts from Jacuzzi.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I forgot I was going to check mine. Mine is a Laser 190L. The center pipe goes down to the black manifold which the laterals attach to. There is no hole in the black manifold. There is an small extension pipe (looks like 1.25' pvc) on the bottom of the black manifold which holds the manifold about 2 1/2 inches above the bottom of the filter.
    Quote Originally Posted by linen
    Thanks for checking. I think I'm going to try to plug the bottom hole in some way. My standpipe is open all the way to the bottom (I can look from the top through the manifold to the bottom extension). It sounds as if your manifold has a closed bottom with an extension.
    If this fails I'll use this site to research what type of filter everyone prefers. Thanks!
    Dawn
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yeah, that is different from mine. What is your filter's model number?
    Jacuzzi Laser Jet 250L
    Dawn
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    As far as I know that filter should have the same internal construction mine does. I have a pdf of the manual at home, I will post it when I get back home.
