Thread: How long will high chlorine last
    Near Nashville TN
    50
    About two weeks ago i was having some algae growth so I got my FC to shock levels- actually, much higher- they were in the mid 30s at times. Well, I have sparkling clean water, but my FC is still very high (mid 20s) I have not added any bleach in over 2 weeks, and it is hot and sunny here- low 90s. I have a swg that is set at 50% as insurance, and my CYA is close to 70. I would have thought these high levels would have dissipated or burned off by now???
    FC 22
    CC 0
    PH 7.4
    CYA 70
    TA 85
    20x40 In ground Grecian Lazy L- Vinyl
    AutoPilot SWG Dig-220, SC-48
    Hayward Dual speed 1.5 hp pump
    Hayward sand filter
    Blue Diamond Robotic Vacuum
    BBB method BABY!!
    Aug 2010
    Dallas, TX
    4,052
    Re: How long will high chlorine last
    Well, your SWG is still adding chlorine. Makes sense to me.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,629
    Kill the SWG for awhile.
    Feb 2012
    Cypress, TX
    131
    What % do you normally run your swg? If it's close to 50% then I can see it taking a while to get the fc levels back down. Shut it down or greatly reduce it for a while and see how it goes.
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    Near Nashville TN
    50
    Question- why kill the swg for a while? Is it hurting anything having FC high- I realize fading of liner, etc...but that's not really a concern. I'm afraid if swg is off and this hot sunny weather continues, good ole algae will return. I do keep at 50% normally and it usually runs +/- 6 FC. It will eventually droop down I'd imagine.
    Thanks again
    Hayward sand filter
    BBB method BABY!!
