Thread: Aquapure - Aqualink 1400- 3 Port Cell and Sensor
    tomfinch's Avatar
    Mar 2012
    Las Vegas, NV
    52
    It's been 3 years and I had to install a new Aqualink 1400 last night. I have the AKC13 board and my old sensor did not have the Tri-Sensor Adapter hooked up to it. I was not getting any 170 or 180 errors on my old unit either. Since the new Cell, Sensor and Power cables I received yesterday did not come with the cable assembly to use in order to install the Tri Sensor Adaper will I be ok? I simply installed the sensor directly to the AKC 13 board without the adapter and it seems to work fine. Will this cause me problems later? If I should by the adapter I will but I don't want to be throwing money away. Also since I didn't put the adapter on I can't figure out how to calibrate the sensor. There is not a calibration button on the AKC13 board like there is on that adapter. Do I need to calibrate without the adapter somehow? Thanks
    [center:2jd6lb8v]16,000 Gal., Plaster, 3.0 HP Jandy, Polaris UltraFlex2, Aquapure 1400 SWG, Fafco solar panels, Jandy Aqualink[/center:2jd6lb8v]
    tomfinch's Avatar
    Mar 2012
    Las Vegas, NV
    52
    Re: Aquapure - Aqualink 1400- 3 Port Cell and Sensor
    Anyone know if I'm ok without the sensor adapter. Seems to be making chlorine fine. I don't want to destroy anything else.
