Results 1 to 12 of 12
Thread: Muriatic Acid, safety questions...
    May 2012
    NE OK
    54
    I have been following the BBB method ever since having a severe algae problem earlier this year. I am the primary care taker of the pool and I asked my husband to get muriatic acid so I could lower the PH. He doesn't like the sound of this stuff and wasn't thrilled about me using it. The water is also sparkling clear right now and he doesn't see why I would mess with anything. I always thought my PH was borderline high but my husband read it in the 7.8 range so I never adjusted it. After 1-2 inches of rain the other night there is no question that it is definitely high.
    My PH is at 8.2 and my TA 140 right now. I have looked for quite some time on the forum but can't find anywhere that says how long after muriatic acid is added do you need to wait to swim? Considering the amount I may need to add (72 oz.) I just don't see how it would be safe for my kids to be swimming and opening their eyes in the pool period. I am concerned about hot spots. Are there no other safer alternatives to lowering PH?
    25,000 gallon
    AG
    Sand
    filter size is 26 diameter
    flow rate 70 GPM
    AG Pool (33ft.) was newly installed in spring 2011
    May 2012
    Illinois
    7
    Re: Muriatic Acid, safety questions...
    I just started using this website. Prior to that, I was dependent on my local pool store. I've used muratic acid for the past 5 years and the pool store recommended it, as does this site. The main issues I've encountered are to avoid breathing in the fumes and avoid splashing it on your skin as you pour it in. I slowly add (by a return jet) the amount recommended by the pool calculator, then let the water mix a while. It does a great job of keeping pH and TA in optimal ranges.
    25,000 gal in-ground, vinyl, 1 HP Hayward Max-Flo pump, 250 lb. SwimPro sand filter, Dolphin Diagnostic robot, TF100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Muriatic acid does require care in handling, but once it is in the pool and mixed, there is no risk. It is heavier than water, so it will settle to the bottom if you don't leave the pump running after addition.
    30,414
    Muriatic is almost instantly dispersed and harmless in a pool within minutes (pump running). There are no "hot spots". You can safely add it in virtually any reasonable dose and swim in 30 minutes.
    The things we suggest here on the forum have been pretty well thought out for several years and thousands of people have been following the procedures suggested with no ill effects.
    That said, it sounds like both of you don't like it so you can use a pool store product labeled "pH minus" or "pH down". I personally don't like it as well and it's more money but it does work.
    Aug 2010
    Dallas, TX
    4,052
    No matter what product you purchase, it WILL be acid if it's purpose is to lower pH. There's no way around it. Low pH products are "acidic", high pH products are "alkaline".
    You could use vinegar, but you'd need a tanker truck of it.
    I added almost a gallon of muriatic acid to my pool last night, and in 30 minutes I was in the pool. I'm still alive to talk about it today.
    Apr 2010
    Buckeye, AZ 85326
    619
    The amount of MA you have to add is very small compared the the amount of water in the pool. As far as your kids opening their eyes under water, our son use to hate wearing goggles. We found a pair at Target made by Speedo that he loves. He even wants to wear them in the bath tub now. It makes a huge difference in the pool when he has them on. Here is a link to the type we bought.
    http://www.target.com/p/speedo-junior-h ... tailbutton
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    If it makes you feel any better, add it at night after you are done swimming and leave the pump running.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Add the acid then brush down the sides of the pool. Mixing and brushing at the same time. Then jump in and enjoy!
    As long as you pour the muriatic acid slowly in front of a return jet while the pump is running, and then wait half an hour with the pump running, it will be completely mixed in an totally safe to swim. Muriatic acid mixes in especially quickly (as long as the pump is running) and as soon as it is mixed it is safe.
    May 2012
    NE OK
    54
    Thanks everyone! I did go ahead and purchase the muriatic acid. I retested my TA and PH again just now. I would say that my PH now looks closer to 7.8 but my TA is still 140. Should I still add the acid to lower my PH?
    25,000 gallon
    AG
    Sand
    flow rate 70 GPM
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    It won't hurt. Dose down to 7.2 or so.
    ~~ Allison ~~
    Mar 2011
    Houston, Texas
    413
    Curlyfry, MA is totally safe if you use some common sense. I've probably added 25 gallons or so of MA to my pool since it was completed in December 2010. Follow the advice above and you'll be fine. I recommend you get the TA down a bit by following the instructions in Pool School and try to keep your pH around 7.6 or so.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
