Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Rookie looking for advice
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    FC - 16
    CC - 1.5
    pH - 7.2
    TA - 100
    CH - 60
    CYA - 30 I think I have been adding CYA to the skimmer in a sock
    Borates - NA
    Bought a foreclosure, uncovered a murky green swamp, initially tried the pool first aid and dichlor, made some difference but then. blah.
    cleaned out all the junk, was running pump 24/7 and pump went out, ugh!
    stopped everything, waited for new pump then found TFP WHEEEW!
    got new pump, went to wally world got bleach, borax, and BS, put new pump on old housing, bubbles, bubbles (was the pump housing of course) cut PVC added new housing, back to running smmoth.
    using Taylor 2006 kit for testing
    tried a copper based algaecide also and wasn't paying enough attention to my water (dumb) and then shocked I think i have metal stains on the walls and fiberglass stairs. I tried the AA test with a Vitamin C tab and it turned the spot bright white? so have ordered the AA to try it after I get the water clear and blue? I tend to bounce around its my ADHD I think. I have well water and added it to the pool already, not sure if that was a big mistake since i think the stains are from the well water?
    Questions:
    1.the stuff to take the metal out Sequestrants, can you add them anytime?
    2. how long should I expect to wait to see blue water?
    20x40 Vinyl IG, 27k gal, 1 hp hayward, s244s hayward SF, Hayward SWG 1 floor drain, 2 Skimmers, 4 Returns, Fiberstars FO lights, Polaris booster, and 380 polaris cleaner.
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    Re: Rookie looking for advice
    update
    as of 10:45 last night
    FC - 17.5
    CC - 2.5
    pH - 7.2
    TA - 110
    CYA - 20-30 cant really tell with the taylor 2006 but continuing to add slowly till I can
    I think my FC is holding at 16 now today as of 0530, pump running, and some sediment, and still green water?
    anyone know of a cheap test kit for metals?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, DLaplante
    It sounds like you are already doing the shocking process?
    That is the first thing for you to do.
    Quote Originally Posted by DLaplante
    Pool stores and water softner stores can test metal concentrations for you. The metals testing kits get a bit expensive.
    Take a look at this pool school article if you haven't yet: http://www.troublefreepool.com/pool-...metal%20stains. It has recommendation sequesterant brands. I wouldn't add any until you are done shocking.
    This is quite variable. With you fairly high CC reading you have a ways to go with the shocking process.
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    Thanks.
    What levels of CC should I be looking for?
    Aug 2010
    Dallas, TX
    4,052
    .5 or less.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The end of shocking criteria is in the shocking process (also in red in my sig), you must pass all three criteria (together) before lower your FC levels below your shock level. Typically CC sill drop down below 0.5 ppm a while before you can pass a OCLT.
    Jun 2010
    Glendale, CA
    513
    If you have a metals problem there may come a time when you have CLEAR green water (this would be the metals making it green)
    As long as the water is murky/cloudy you are still fighting a problem with organics in the water.
    It will take a while to oxidize and filter out all the algae etc. from the water (a week or two) - so stay the course with the shock process. If after a week your water seems to be clearing but is still bright green you can worry about metals.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    Ok just re-read the article, Ill keep at it. thanks all for the replies.
    Articfox918's Avatar
    May 2012
    Western, Wisconsin
    99
    I also am on a well and have a a big Manganese and iron issue. I would once and awhile get the clear green water as stated above when I needed to fill due to evaporation or big splash out. I have used the PRO TEAM Metal Magic and works good for me. What I was doing before was adding water then testing and adding my bleach per pool calculator. I would wake up the next morning and BAM! Clear green water! I would then add the sequesterant and that would clear it up. What I have been doing recently is add a bit of the sequesterant prior to filling and let that run for a few hours then test and add needed chemicals. I haven't had an issue since I started that method with water changing colors. I am still playing with the amount of sequesterant VS water added ratio to determine my bottom line threshold but water has stayed crystal clear since I have been doing this.
    As Linen stated shock till you pass those three criteria together and you will be OK
    Oh and Welcome The people here know what they are talking about so follow and listen and master Pool School!
    POOL SIZE: 27 FT round 52" Deep on edges 66" Deep in center
    FILTER TYPE: Hayward Sand Filter
    PUMP SIZE: Hayward 1 HP Pump 60GPM
    FILTER SIZE/FLOW RATE: Unknown
    HEATER: None at the moment but in process of making my solar panels should be operational by next season!
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    Thanks I have already ordered the PRO TEM i did see it in another thread and decided to just get it, looks like i made a good decision.
    New question:
    I tested this morning and had a FC 16, last night 17.5, and I had my daughter test today at 1230 and she gave me 53 drops? now I calculate that to be 26.5ppm how did it go up without adding bleach? am i loosing my mind, or did she do something worng? IDK thoughts?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    On a side note, I noticed your sig details about a change coming to your filter...why do you want to go to the C1200 filter from the S244 filter? The S244 filter is better sized for your pool.
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    Seemed like the maint for a Cart. was easier and you didn't loose water like when backwashing, then I wouldn't have to use the well water so often.
    I was going off inyo web site http://www.inyopools.com/Products/02201359046019.htm for size filter and pump for my pool with gals. and feet of head? do you think i may have miscalculated? for my 27000 gal pool??
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Our recommendation would be at least a 400 sq. ft. cart filter.
    For a sand filter our recommendation would be 5.0 sq. ft., though if you went to that size, we would need to see if your pump could still backwash it.
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    ohh I almost forgot I did already buy them, and got the 1hp pump, to replace the failed 1.5hp pump do you think that may be a mistake? I thought they seemed a little small but figured they "knew" what they were talking about?
    What model would I be looking at for 400sf?
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    I really need to be more clear I meant what model would be a good fit for your recommendation of a 400 sq. ft. cart filter, not a 400sand filter, duh sorry!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    This would be better: http://www.inyopools.com/Products/02201212000436.htm...it is 425 sq. ft.
    Your pool is bigger, and it really comes down to how often you have to clean it...and cleaning a cartridge filter takes a lot more time than backwashing a sand filter.
    Generally a smaller pump is prefered, but water features, jets etc. can drive the need for higher flows. Do you have any of these?
    Also, since you were in the market for a new pump, many people benefit from 2-speed pumps, and run on low most of the time to save electricity.
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    ok Maybe I should stick with my sand filter after seeing the price of the one you suggest. I will be keeping the sf in place till i get the water balanced.
    Q: what do you mean by "your pool is bigger" do you think my calculations may be off?
    currently no water features, just 2 skimmers, one valve for the main drain i think, 4 returns.
    a polaris booster that sounds like the shaft is locked up and will try to turn, working on that.
    a mineral thing. IDK? heater not sure on the model as the label is rubbed off, and there was an ozone thing that didnt work, i took it off.
    it had not been even touched in 2 years. and Im a rookie all help is very much appreciated. thanks
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    pump and filter[attachment=0:34pdvcd2]IMAG0652.jpg[/attachment:34pdvcd2]
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Sorry, I meant on a continuum of pool sizes, it is larger then many, therefore the equipment requirements are more significant. I have not checked your volume calculations.
    Your existing sand filter is 3.2 sq. ft, so though it is small for what we would recommend, it will (and obviously has) work just with more frequent backwashing. Are you having any problems with it?
    a mineral thing.
    I wouldn't use it, you don't need it or what it is adding (usually copper, silver, and/or zinc).
  20. Back To Top    #20
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    Filter/Minearal thing
    I replaced the sand and inspected, it seemed fine, multiport needed a new gasket under the handle, being a rookie i ordered a whole new valve, and after carefull evaluation decided not to cut into the PVC just yet and put the new top on the old body, gasket was not too bad, although i wanted to replace it with the one that came in the new valve it was glued in and i didnt want to tear it out, so i may wait till i re-position the whole set-up since the current "design" leaves no room for maint, or protection from the Minnesota elements.
    Mineral: not sure i will keep it.
    I want to dig it all out and pour a concrete slab, then position all of the equip in a way that makes sence for maintenance. maybe even make a half shelter of some type.
    I was thinking of using flexible PVC for the above ground stuff, so I can just take the pump in in the winter, thoughts?
    thanks.
