Results 1 to 9 of 9
Thread: Will the Liquidator work in my setup
    Jun 2010
    San Antonio
    424
    I am interested in the Liquidator, but not sure it will work without a modification of my plumbing. My pump sits directly below the skimmer with a 2" pvc pipe between them. The straight down drop is about 30". I don't understand the physics, but I have read that there needs to be resistance between the skimmer and the pump for the liquidator to work. Is this correct and how do I know whether the Liquidator will work with my plumbing? TIA
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    22,549
    Re: Will the Liquidator work in my setup
    The question is not will it work, it's what will you have to do to get it to work? And are you willing to do it.
    Given your low suction head you'll most likely have to add a restriction to the suction side to get it to work correctly. If you have a valve just below the skimmer, that might be enough, depending on what type it is.
    What does your filter pressure run?
    Jun 2010
    San Antonio
    424
    I do have a ball valve between the skimmer and the pump. The pressure runs about 8 and it rarely gets high enough to require backwashing. Normally it runs around 8 for months. I usually backwash a couple of times during the summer just because I want to and not because the pressure has gone up.
    Larry in Texas
    22,549
    With a filter pressure of 8 psi you may have a good bit of suction head and if that's the case, the LQ should work fine without doing anything to the plumbing.
    Jun 2010
    San Antonio
    424
    Thanks Dave. If it turns out I need to change the plumbing, would it be best to decrease the size of the pvc or run more pipe to make it a longer run? Would either of these increase the suction head?
    Larry in Texas
    22,549
    Your best way would be to put a restriction in the line. Even closing off the suction valve will work unless you have someone that would open it for you without asking. My sis runs with her suction valve partially closed in order to get the LQ to work right.
    Txmat,
    I can make you a great deal on one if you decide to go that way. I used mine for 3 months and am just north of San Antonio. PM if you are interested.
    22k gal, gunite, Pebblesheen, fountain/waterfall, no spa, Quad 100DE, Easytouch4, Pentair VS3050, Polaris 280, TFP-100 kit, Stenner pump
    Jun 2012
    Farmington wv
    92
    I am also thinking about getting a liquidator and will have the same problem I have a bit more restiction with a 1-1/2 pipe.
    13500 gal 24 foot round x 4 foot deep above ground pool. Sand filter with 1.5 hp pump. City water
    22,549
    I saw your posts in the other thread. You'll either have to close the suction valve off partially or add an artificial restriction. As short as your suction pipe is you have almost no suction head.
