Thread: Stabilizer vs. Clarifier
    Jun 2012
    Howard City, MI
    54
    What is the difference between a stabilizer and the hth Natural clarifier? Will the clarifier help to raise the CYA?
    Above-Ground Pro Series 18'x48" Metal Frame - Approx 6,450 gallons
    Skimmer Filter System (cartridge): SFS1000 w/ F1500C Pump: 120watts/2.0amps/1500g.p.h
    Purchased & Installed: 6/7/12 (week of)
    Guest
    Re: Stabilizer vs. Clarifier
    Clarifier does not add CYA
    May 2012
    Illinois
    7
    As I understand it, clarifier is used to get particles that are suspended in your water to clump together and sink to the bottom so you can vacuum them up. I used it once when I had killed a bad algae outbreak and the dead algae was making the water cloudy. However, most recently when I killed algae (after I started using this website) I patiently waited for the dead algae to be filtered out by my sand filter. It took a week or so, but now my water is beautiful, and I didn't have to vacuum up the muck from the clarifier. I backwashed the filter, keep my Cl levels where they should be, and the pool is crystal clear!
    25,000 gal in-ground, vinyl, 1 HP Hayward Max-Flo pump, 250 lb. SwimPro sand filter, Dolphin Diagnostic robot, TF100 test kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by Terrjam
    drmercer explained clarifier. Stabilizer (AKA cyanuric acid) protects FC from the sun. Without CYA in your pool, ultraviolet radiation will degrade your FC before it can do its job.
    Mar 2007
    San Rafael, CA USA
    12,082
    What was described in consolidating particles to have them settle to the bottom to vacuum them up is usually called a flocculant. A clarifier also consolidates particles, but not so much as to cause them to fall to the bottom, but instead is designed to have them circulate to the filter where they then get caught and later removed via cleaning/backwashing of the filter.
