Thread: Best way to drill/punch holes
    Replacing my AGP widemouth skimmer and the screw holes on the new one are not in the same places as the old one. All the screws are on the same planes, just spaced differently. So I'll have to make some new holes. I want to avoid sharp metal shavings getting into the pool for obvious reasons. Would it be best to tap an awl thru the wall to make them as opposed to drilling?
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    22,542
    Re: Best way to drill/punch holes
    I don't know about driving an awl or punch through the wall as that will produce a raised cone around the hole and that may cause you sealing issues.
    You can drill the holes from the outside and coat the drill bit with thick silicone grease to catch the shavings. Also a piece of tape on the inside with a glob of grease behind it will catch any that go that way. Or someone holding a shop vac hose against the inside will capture them as well.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd invest a couple bucks in a brand-new sharp drill bit. That will help you get one of those long spirals rather than small flakes. And I'd stick a big magnet right below where I was drilling. It will also help grab anything that may have escaped when you're all done.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Another option. Get a big ball of playdough and hold it over the water side where the bit is to come though. Be careful though. The clay will stop the shavings. The magnet option is a really good one too.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
