Thread: How much bleach
    Jun 2012
    MA
    347
    How much bleach
    I just set up my new 15" - 4 pool this week. I am bringing up the CYA level, I am adding 16 oz pool conditioner each night for three nights. I have decide to try bleach this year instead of tablets. I have used the pool calculator. I am wondering what an average amount of bleach will I expect to add every night or other night.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: How much bleach
    1380ken:
    Managing how much bleach you need to add to maintain the appropriate FC level in your pool is known as chlorine demand. This is dependent on several factors including the # of gallons of water in your pool, the strength % of your bleach, the CYA level, amount of sunlight your pool gets each day, water temperature, bather load, and how diligent you are in keeping the pool free from debris (skimming leaves out, vacuuming, etc.). You will get a feel for your pool's normal chlorine demand with experience. Even after you get a feel for that, you will need to make occasional adjustments for events like pool parties, heavy rain (can introduce organic matter into the pool), etc. All other things held constant, chlorine demand tends to drop as water temperature drops and rises as water temperature increases.
    Continue using the Pool Calculator. It will give you the correct information based on your inputs.
    BTW, what is the "pool conditioner" you are adding? Is that the CYA (stabilizer) or something else?
    Jun 2010
    Glendale, CA
    513
    Re: How much bleach
    You'll loose somewhere around 2-3ppm a day on average. Use Pool Calc to determine how much bleach that is based on your gallons. Obviously this is just an estimate - but will give you a good idea of how much bleach to buy if you wanted to stock up for a few weeks.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Jun 2012
    MA
    347
    Re: How much bleach
    The conditioner is CYA. I am adding enough to get to 32 ppm. My pool gets about 1/2 sun. I was thinking that 32 ppm should be high enough. I am planning on shocking it once a week with pool essentials shock, which I think is just chlorine. I need to check what is in the shock. I could just shock it with bleach but I bought the shock.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: How much bleach
    If you keep your FC at the appropriate level, there is no need to shock, especially not a weekly shock.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: How much bleach
    Quote Originally Posted by 1380ken
    Be careful! That "shock" may drive your CYA through the roof, rendering your chlorine ineffective, which ultimately will lead to a cloudy and/or green pool. Or it could add Calcium, which can cause cloudiness and scale. And if it does start scaling, you won't be able to use a wire brush to loosen it, with a vinyl liner. And provided you always maintain enough chlorine for your CYA level, you may never need to raise chlorine to shock level. Ever.
    My advice: read Pool School carefully.
