Thread: Does anyone sell pucks w/o CYA?
    Jun 2012
    Long Island, NY
    102
    Thanks - John
    Pool: Sharkline Matrix 18 Round 54 Deep
    Pool Size: ~8200 Gallons
    Filter Type: Sand
    Pump: Intex 2650
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Does anyone sell pucks w/o CYA?
    If you google cal hypo tablets it will pull up some sites that sell them. Cal hypo tablets do not contain CYA, but the do contain calcium and will raise your calcium level. If your water is naturally low in calcium that may not be a problem. If there are no water restrictions in place where you live you can drain and refill if the calcium becomes problematic.
    Love TFP? Become a
    TFP Supporter!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    In order to get chlorine in a solid form you will be adding something to your pool that you don't want or need its either CYA or calcium. Liquid chlorine or bleach only results in a trace amount of salt. The only pure chlorine is in gaseous form and only huge pool complexes and water treatment facilities use chlorine gas. Of course there is always the salt pool option where a SWG breaks down the salt to release free chlorine then its recombined back into salt in the pool water leaving no additional chemicals in the pool.
    chiefwej
    Cal-hypo dissolves way to quickly to be used in the same way that trichlor tablets are used.
    No; however, you can buy LC at walmart that has stabilizer. I noticed it the other day... WHY!?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
